high compression causing starter issues
Old Dec 27, 2004 | 08:19 AM
cervasa's Avatar
New User
Default high compression causing starter issues
alright now that ive got my ls vtec setup complete and my compression is around 11.1-11.3 my starter has a hard time turning the engine over has anyone else ever had this problem??? if so how did you resolve it?
Old Dec 27, 2004 | 08:40 AM
lohatch's Avatar
Default Re: high compression causing starter issues (cervasa)
i have never had a prob, but maybe your starter is worn. JCwhitney sells starters for high compression motors but they are like $400. i would just source another stock one and try that.
Old Dec 27, 2004 | 08:43 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: high compression causing starter issues (lohatch)
My 12.2 LSVTEC cranks fine with OEM starter.
Old Dec 27, 2004 | 09:35 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: high compression causing starter issues (LSVTEC 91 Civic)
12.5:1 CR on a D series and OEM starter has no issues.
check your grounds and charging system
stan
Old Dec 27, 2004 | 10:05 AM
six sigma racing's Avatar
Default Re: high compression causing starter issues (Stan D)
my full race motors fire up with a OEM starter no problems.. i doubt its your starter.. check all your connection make sure you are getting clean voltage to the starter
Old Dec 27, 2004 | 11:20 AM
A train's Avatar
Default Re: high compression causing starter issues (DTR-FAB)
i agree with danny check your wiring and make sure the input tab on your wiring harness is tight. at the starter.
Old Dec 27, 2004 | 01:01 PM
johnzm's Avatar
Default Re: high compression causing starter issues (A train)
who built your motor?
a friend had the same issue, and had horribly tight bearing clearences (engine failed within 25 miles)
i had a 13.9:1 motor and never had issues getting it to turn over with a oldskool 1st gen JDm starter (came with an engine swap from a 1990 CRX SIR)
see how easy it is to turn that motor over by hand
Old Dec 28, 2004 | 10:48 AM
cervasa's Avatar
New User
Default Re: high compression causing starter issues (johnzm)
your scaring me with the tight bearing clearences but i dont think that would be it the guy who built it said that he used plastigauge to make shure it was right but ill check all that other stuff
i was told that all manuel b series starters will work is that true if so im thinking ill try a b16 starter since it was built for a higher compression
Old Dec 28, 2004 | 11:03 AM
jdmoutlaw's Avatar
Yes, you can use the b16 starter.
Did you try to spin the motor over by hand?
Check your grounds to the engine and the + lead to the starter.
Modified by jdmoutlaw at 2:15 PM 1/11/2005
Old Dec 28, 2004 | 11:45 AM
Sweet95Civic's Avatar
Default Re: high compression causing starter issues (jdmoutlaw)
Check your battery post for corosion..make sure there nice and tight..and check your main starter cable for corosion,tightness on starter,etc...
Old Dec 28, 2004 | 05:45 PM
cervasa's Avatar
New User
Default Re: high compression causing starter issues (Sweet95Civic)
im starting to think its my starter kill is worn out i think im going to start with removing that but thanx for everyones thoughts
joiv21
Sep 17, 2012 01:09 PM
98integralsB18
Sep 19, 2011 05:54 PM
DarkSol97
Oct 11, 2006 04:33 PM
The_Head
Nov 7, 2005 04:55 AM
