Help a guy out....... Please :)
Old Dec 27, 2004 | 05:39 AM
mp5o's Avatar
Default Help a guy out....... Please :)
Ok... So now i've ordered a Y8 head minus the valve cover, distributor, intake manifold, injectors, fuel rail, ecu, and throttle body.... The head will be put on my 99 civic cx with a d16y7 powerplant(hardly what you'd call a powerplant). I'm having trouble locating the rest of the parts. I called a local honda junk yard and got a quote for just a Y8 intake manifold... Guess how much?? $$250....... Yea sure I'll jump right on that one... But anyways, on topic.... What i listed above, thats exactly what i need to replace right? I have a feeling im missing something. If any one is around the gwinnett/atlanta, GA area with some parts i need let me know. (let me know if your not in the area but willing to ship ) Sorry for the long post, but thanks in advance to anyone who replies. Any help is appreciated!
Old Dec 27, 2004 | 06:31 AM
mp5o's Avatar
Default Re: Help a guy out....... Please :) (mp5o)
No one? Ah well, i guess i'll go to take a nap. Cya soon
Old Dec 27, 2004 | 07:42 AM
snatch's Avatar
As far as the head goes, you should be good. Make sure it has the knock sensor and the VTEC solenoid all intact.
For a Y8 manifold, look around here in the classifieds, I picked mine up for $50 + shipping.
You will need the ECU from an EX for sure, and I'm not 100% sure on the distributor. I think you can use the stock one you have now...
Do a search for "mini-me" and there is a post somewhere with a complete parts list to do this swap. Don't forget to select archive posts either.
Good luck.
Old Dec 27, 2004 | 08:28 AM
wilsel's Avatar
Default Re: Help a guy out....... Please :) (******)
For the rest of the parts check either the classifieds, ebay, or a local place called Alpharetta Auto Parts.
Old Dec 27, 2004 | 08:51 AM
92 EH2's Avatar
Default Re: Help a guy out....... Please :) (wilsel)
for $250, just get the Skunk2 IM...but other than that, search classifieds here.
Old Dec 27, 2004 | 08:52 AM
huntarrr's Avatar
also, make sure you have a 99-00 EX ecu.. a 96-98 will not do.
Old Dec 27, 2004 | 06:29 PM
mp5o's Avatar
Default Re: Help a guy out....... Please :) (vsm98civic)
Thanks for the help guys. Just wondering... would my y7 valve cover fit the new head? And also do i need a y8 timing belt?
HONDA TECH IS MY NEW HOME!!!
Old Dec 27, 2004 | 06:47 PM
99hatch's Avatar
the knock sensor is on the block i believe, not the head
Old Dec 27, 2004 | 07:15 PM
mp5o's Avatar
Default Re: Help a guy out....... Please :) (99hatch)
My cx is a manual... I need a manual p2p ecu, manual intakemanifold right?
Old Dec 28, 2004 | 03:26 AM
mp5o's Avatar
ok i just ordered a manual p2p 99-00 ecu... For the intake manifold, throttle body, fuel rail, injectors, etc do i need a 99-00 manual ex parts for each or will the 96-00 parts work also?
Old Dec 28, 2004 | 03:49 AM
civic-4-ges's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mp5o &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering... would my y7 valve cover fit the new head? And also do i need a y8 timing belt?</TD></TR></TABLE>
Yes, your y7 valve cover will work just fine. YOu may also want to check out http://www.d-series.org (shamless plug). There are always y8 mani's for sale on our site
Old Dec 28, 2004 | 03:57 AM
zeroice's Avatar
96-00 parts will work fine. I have a 98 ex intake manifold i could sell ya..
Old Dec 28, 2004 | 04:06 AM
mp5o's Avatar
Default Re: Help a guy out....... Please :) (zeroice)
Do you have the injectors, fuel rail, and throttle body also? Get on aim and im at mp5o ... im still under noob restrictions. :/
Old Dec 28, 2004 | 04:18 AM
snatch's Avatar
You should be able to use your fuel rail and injectors from your Y7, I did at least.
As far as the throttle body I used my Y7 one with a little modification, or you can get a Y8 and use the throttle plate from it.
99hatch You're right, the knock sensor is on the block, not the head. :hammerhead:
Old Dec 28, 2004 | 04:26 AM
mp5o's Avatar
hmm so could i just use the whole y8 throttle body or just the throttle plate... If you could, i'd like to hear about how you modified your y7 throttle body for it to work...
Edit: Marks off injectors, fuel rail from the list
Old Dec 28, 2004 | 05:36 AM
snatch's Avatar
When I used my Y7 throttle body, the only reason it wouldn't work is the hole where the throttle cable attaches. So, I drilled a hole in the throttle plate to make the throttle cable work.
If I remember right, the hole for the throttle cable on the Y7 is at the bottom of the plate (if you're looking at the throttle body from the front of the car head on). I made a hole near the top of the plate so the cable wraps counterclockwise around the plate at then attaches at the top.
Hope that desciption helps a little, wish I had a picture handy.
Old Dec 28, 2004 | 06:34 AM
zeroice's Avatar
hey i dont have access to aim... its just the bare im i got a skunk2 instead...
email me if ya are still interested b.castleberry@auab.centaf.af.mil
Old Dec 28, 2004 | 06:34 PM
mp5o's Avatar
Thanks for the info ******. Do you think you could snap a few pics of it? Zeroice: Do you know if my y7 sensors will work or do i need the y8 ones too?
Old Dec 28, 2004 | 06:54 PM
There are not a lot of "sensors" to swap over. You will find your Evap purge valve will bolt up to the y7 fuel rail if you remove the metal bracket that holds it, and that there is the same number of vacuum sources. Your y7 TB will control your idle, and your TPS and MAP which are on that TB, are the same as the y8.
Old Dec 28, 2004 | 11:11 PM
mp5o's Avatar
Default Re: Help a guy out....... Please :) (civic-4-ges)
Hmm... Do i need to buy new head bolts? or is it recommended? When i buy a head gasket i buy it for the y8 am i correct? Also if i purchase a bare y8 IM what sensors would i have to buy? Thanks for your time!
Modified by mp5o at 12:36 AM 12/29/2004
Old Dec 29, 2004 | 07:47 PM
zeroice's Avatar
all your sensors should swap over from the y7 manifold to the y8 manifold
BeatDX
17
Mar 26, 2014 06:12 AM
99hatchboy
Jul 17, 2005 05:13 PM
russianrocket21
Feb 24, 2005 07:24 PM
civicmatt
Jul 3, 2003 10:13 AM
