1995 Honda Civic oil change?
Old Dec 26, 2004 | 09:11 PM
gtpsleeper's Avatar
Default 1995 Honda Civic oil change?
Is the oil drain bolt 17mm?
I will be checking the oil level when adding oil but what is the usual amount needed for these engines? I have heard it was 3.7-4qts.
Thanks!
Old Dec 26, 2004 | 09:20 PM
Street Ghost's Avatar
Default Re: 1995 Honda Civic oil change? (gtpsleeper)
17mm Drain Bolt; Torque to 33 lb.ft
Pour in 3.5 Qt. and then check it and add if neccessary.
Old Dec 26, 2004 | 09:26 PM
gtpsleeper's Avatar
Default Re: 1995 Honda Civic oil change? (_Edge.ONE)
THANKS!
Old Dec 26, 2004 | 09:29 PM
Evs-One's Avatar
Solbros Owns Me
usually about 3.5-3.8 with filter change
always use a new crush washer and never over tighten, do like the man said, 33 ft lbs
ShaneDur
Sep 23, 2015 04:36 PM
Bstorm
16
May 27, 2010 10:36 AM
Nighthawk R18
Honda Civic (2006 - 2015)
30
Jul 10, 2008 10:02 PM
Edwin
Jun 16, 2004 06:30 PM
MiraiZ
Jun 12, 2003 05:04 PM
