sir front end
Old Dec 26, 2004 | 07:40 PM
EF9 JAMS!!!'s Avatar
Default sir front end
if i order the front bumper. do i need the radiator support aswell or can i just fit it on with out any problem?
Old Dec 26, 2004 | 09:25 PM
tealjdmcrx's Avatar
Default Re: sir front end (hatch91JDM)
I'm not 100 percent sure but i know that you do need the radiator support if your converting the front end .
Old Dec 26, 2004 | 09:42 PM
shortSHIFT's Avatar
Default Re: sir front end (2ndgenrx)
yo do it in order to latch the hood shut....most of the time the rad support is included in the order if you were to purchase it as a conversion which is way cheaper than buying peice by peice!
Old Dec 26, 2004 | 10:04 PM
skittyscott's Avatar
Default Re: sir front end (shortSHIFT)
.....even if you get the sir rad support, you're going to have to grind the bolt holes on em to move the catch so that the hood will latch correctly. the only difference in the rad supports is the spot where the intake comes through on the jdm piece. instead of spending the $ and then having a big square hole in your rad support, modify yours.
*edit*
whoa.. my 100th post and it only took me 2-1/4 years.
i just thought that was exciting
scott
Old Dec 27, 2004 | 07:22 AM
JDM RHD eg6's Avatar
Default Re: sir front end (skittyscott)
NO you dont need the rad support, not even the jdm sir fenders, because the fenders are the same thing, but with no jdm sidemarkers.
Old Dec 27, 2004 | 07:30 AM
picasso1's Avatar
Default Re: sir front end (MrEF8)
I used the bumper mounts and the supports on the sides; in addition to the rad support for my EF9 conversion, and i still needed to modify the rad support to shut the hood.
Old Dec 27, 2004 | 08:41 AM
UltimX's Avatar
Default Re: sir front end (picasso1)
No you do not need the bumper support.
Old Dec 27, 2004 | 06:12 PM
Default Re: sir front end (UltimX)
well i'll put it this way i plan on putting just the front bumper on becasue i can get it for a steal i just don't wanna have to deal with looking for everything if i make a mistake.
Old Dec 27, 2004 | 06:37 PM
UltimX's Avatar
If you can get it for a steal then hook me up with your deal.
crx_si-r
Jun 13, 2009 03:32 PM
ef9robert
Mar 26, 2008 04:27 PM
br'Y'an
Oct 5, 2006 02:22 PM
crx_ef8
10
Mar 7, 2004 04:16 AM
CRXJUICE
May 21, 2003 02:35 PM
