help on my harness bar design
Here are some pictures of how its comming so far it is gona be sent out to a welder this week because i dont have the equpment to weld aneything this big
sorry about the huge images
Modified by cstay at 4:45 PM 1/9/2005
Modified by cstay at 11:52 PM 1/9/2005
new question if i have a place put a bend in two pipes would i be able to put a smaller pipe inside of the larger one then weld around so the center where the weld would be it would be stronger with a pipe in the center of it this is so i can have somthing bent and be able to change the leingth because if they bend it without the car there they probally wont be able to get dead on
That angle is too much.
Are you saying you want to bend it so its a "U" and the ends of the U attach to the seatbelt mounts and the middle is closer to the holes?
Also what are you using this bar for, please don't use it on the track.
https://honda-tech.com/zerothread?id=978258
YAH YAH
Dec 10, 2007 02:45 AM
rev210k
15
Aug 12, 2006 03:45 PM
jdmspoonitr
15
May 23, 2003 11:31 AM
BDiddy
Jul 31, 2002 03:15 PM
