vtec stopped working
Old Dec 26, 2004 | 11:20 AM
97gsrEK's Avatar
Default vtec stopped working
since it has snowed here in cincy my vtec stopped working. i checked my oil level and unplugged the ecu and still no. i have a h22a1 in a 97 civic. just trying to figure out what it could be? the motor has about 60.000 on it. any ideas? car has been fully warmed up on every attempt. usually revs to 7500 but is revlimited to 6800??
Old Dec 26, 2004 | 11:27 AM
hb_guy's Avatar
Default Re: vtec stopped working (97gsrEK)
are you still running obd2 or obd1? and check your ground for the vtec solenoid and pressure
Old Dec 26, 2004 | 11:29 AM
97gsrEK's Avatar
its obd1
Old Dec 26, 2004 | 11:40 AM
92jdmhatch's Avatar
Default Re: (97gsrEK)
Vtec... Who needs it anywa? lol jk....Start from your wiring harnes..make sure everything is still cool...then vtec solenoid....then....also my friend had a problem with this distributor and had no vtec ..just go throught the basics before spending money...
Old Dec 26, 2004 | 12:13 PM
primeredbeast's Avatar
my vtec starts acting up when my gas tank get a little low might be a factor??
Old Dec 26, 2004 | 12:30 PM
arielb1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97gsrEK &raquo;</TD></TR><TR><TD CLASS="quote">since it has snowed here in cincy my vtec stopped working. i checked my oil level and unplugged the ecu and still no. i have a h22a1 in a 97 civic. just trying to figure out what it could be? the motor has about 60.000 on it. any ideas? car has been fully warmed up on every attempt. usually revs to 7500 but is revlimited to 6800?? </TD></TR></TABLE>
Sorry, if you could please teach me on how you were able to tell the VTEC stopped working? My apology for high jacking, but I wanted to take the oppurtunity to learn.
Old Dec 26, 2004 | 01:15 PM
97gsrEK's Avatar
Default Re: (primeredbeast)
nope full tank of 93. the way i could tell the vtec stopped working is becuase you don't hear it switch over at high rpms and there is no power gain where it should be.
anyone else have any idea. i have a skunk2 chipped p13 obd1 ecu. all wires and sensors look fine from what i can tell. i unplugged and replugged the ecu. still nothing. i'm about to just take it to honda and let the mess with it cuz i am clueless on this. i really doubt it is the vtec solenoid since the motor has very low milage. full gas. oil is fine. any ideas? and any estimates on what honda will charge?
Old Dec 26, 2004 | 01:53 PM
97gsrEK's Avatar
bump anyone know anything?
Old Dec 26, 2004 | 02:50 PM
Falqon's Avatar
you are letting it get nice and warm right?
Old Dec 26, 2004 | 02:59 PM
blackeg's Avatar
Default Re: (Falqon)
are you getting any engine codes???
also, the vss is important regarding vtec activation, and the connections are very sensitive.
Old Dec 26, 2004 | 04:22 PM
B18C2_sedan's Avatar
try a friends ecu and go from there. Keep it simple
Old Dec 26, 2004 | 04:24 PM
boostedcivicsir's Avatar
Mr. Badwrench
you may have a thermostat keeping it in open loop. it may be warm but not that warm.
Old Dec 26, 2004 | 05:01 PM
Mr_GaBIG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Falqon &raquo;</TD></TR><TR><TD CLASS="quote">you are letting it get nice and warm right?</TD></TR></TABLE>
Old Dec 27, 2004 | 02:05 PM
97gsrEK's Avatar
Default Re: (Mr_GaBIG)
yeah i'm letting it fully warm up. ive noticed the heat does not blow hot, its not as warm as it should be. my check engine light is not plugged in, and i didnt think you could check obd1 for codes?
Old Dec 27, 2004 | 03:03 PM
Mr_GaBIG's Avatar
This may sound stupid, but have you checked your oil level?
Old Dec 27, 2004 | 03:06 PM
ABK's Avatar
ABK
check for codes, then get a voltmeter and tap it into vtec solenoid wire (A4), and see if it's going to turn on. If it is you got problems with your solenoid or oil delivery.
IF it does not kick in, bad pressure switch, some other issues.
Old Dec 27, 2004 | 03:27 PM
Falqon's Avatar
Default Re: (ABK)
if his heat isn't coming on enough, I'm guessing thermostat is keeping his water too cool.
Old Dec 27, 2004 | 03:32 PM
ABK's Avatar
ABK
oh so your engine doesn't heat up. what's does the temp gauge read?
Old Dec 27, 2004 | 04:19 PM
97gsrEK's Avatar
temp guage is right in the middle where it should be. i put 87 in it last week and since then its been in safe mode. only reason for the 87 was the gas station was out of 93. and yes i have checked my oil. i just changed the oil.
Old Dec 27, 2004 | 04:42 PM
ABK's Avatar
ABK
well that's could be your problem. Does your motor have knock sensor?
If it does your motor started to knock on 87 and ks detected knock pulled the timing, richened up the mixture, and disable the vtec. Run out of 87 and put some 93 in there, and reset your computer (pull battery cables and touch them together).
Old Dec 27, 2004 | 08:54 PM
Falqon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97gsrEK &raquo;</TD></TR><TR><TD CLASS="quote">temp guage is right in the middle where it should be. i put 87 in it last week and since then its been in safe mode. only reason for the 87 was the gas station was out of 93. and yes i have checked my oil. i just changed the oil.</TD></TR></TABLE>
your temp gauge must be a cold one, or a narrow one. In georgia my temp gauge barely goes up 1/4 of the way, and it's a whole lot warmer here than in ohio.
heaters not working, bad gas, geez why does everybody wonder why vtec isn't working when they should be concentrating on other problems.
valentine97
Dec 6, 2007 08:38 PM
92H23VTEC
Nov 25, 2007 06:49 PM
slammed_92_accord
Apr 27, 2006 07:46 PM
lmiguelvv
Oct 19, 2004 06:55 PM
97dc2
Sep 23, 2004 12:00 AM
