heater problem
Old Dec 26, 2004 | 10:57 AM
Blackmagik's Avatar
Default heater problem
it's cold and my heater no workie.
yes i did a search, no i do not have coolant in the passenger floor. i did find that the valve that the cabin controls opens and closes don't move with the cabin controls and i'll fix that when it's not so cold outside. i manually put the valve to open and duct taped it in place for the time being and still no heat. any ideas? i've gone through about all i can think of.
Old Dec 26, 2004 | 11:03 AM
jlacoy82's Avatar
71.192.16.183
Where do you live, what have the temps been and have you covered part of your radiator yet?
Old Dec 26, 2004 | 11:08 AM
Blackmagik's Avatar
Default Re: (jlacoy82)
northern va... temps have been around ~10-20 lately, but it's been this way ever since it first started cooling off and i really didn't think anything of it. IIRC the coolant going into the heater coil should be ~180F and it seems that the hose going into that valve gets warm enough from the coolant at idle. the coil just never heats up. with my luck it's probably that valve that's fuckered. anyone know what that valve is called?
Old Dec 26, 2004 | 11:09 AM
jlacoy82's Avatar
71.192.16.183
Have you tried replacing the thermostat?
Old Dec 26, 2004 | 11:11 AM
Blackmagik's Avatar
no because the car stays at a constant temp both at idle and while driving
White_EG1
Sep 18, 2016 11:41 AM
thewrai6th
Mar 10, 2016 04:24 PM
Shaw14
Dec 21, 2009 12:30 PM
Acidcrakker
Dec 9, 2007 04:14 PM
ZC88CRX
Nov 9, 2003 08:03 PM
