Running amp wires
Old Dec 26, 2004 | 10:44 AM
Rickdogg's Avatar
Default Running amp wires
hey can someone help me whats a good way to run all the wires for an amp on a 89 crx thanks
Old Dec 26, 2004 | 10:58 AM
Shaguar47's Avatar
Default Re: Running amp wires (Rickdogg)
Yeah, I want to know too
Old Dec 26, 2004 | 12:24 PM
NONVTECSI's Avatar
i ran mine from the passenger side through one of the holes (power wire), right behind the glove box. Then I ran it under the right side all th way to the back trunk space... My head unit has a sub out so i ran that under the left side...
Old Dec 26, 2004 | 12:37 PM
crxgator's Avatar
Default Re: (NONVTECSI)
thats what i did as well...it stops ground noise...
Old Dec 26, 2004 | 03:47 PM
Rickdogg's Avatar
alright cool thanks
Old Dec 26, 2004 | 08:14 PM
doublethink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NONVTECSI &raquo;</TD></TR><TR><TD CLASS="quote">i ran mine from the passenger side through one of the holes (power wire), right behind the glove box. Then I ran it under the right side all th way to the back trunk space... My head unit has a sub out so i ran that under the left side...</TD></TR></TABLE>
excellent way of doing it.
Old Dec 30, 2004 | 05:58 PM
Rickdogg's Avatar
i just got one more question where did u ground it at did u run that with the power wire
Old Dec 30, 2004 | 06:29 PM
Default Re: (Rickdogg)
the cleanest way to do it?
use the factory ground found by the liftgate latch, behind the plastic, its a single 10 mm bolt.
that way you drill no holes.
also some people have the battery relocated to the back, which would obviously make that a no brainer decision.
Old Dec 30, 2004 | 07:37 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickdogg &raquo;</TD></TR><TR><TD CLASS="quote">i just got one more question where did u ground it at did u run that with the power wire</TD></TR></TABLE>
a ground wire is suppose to be less than 3ft in total and the shorter the better...i have my ground under the carpet by the ebrake and i have my amp in the storage container...
Old Dec 30, 2004 | 07:47 PM
Rickdogg's Avatar
Default Re: ([crx]I 3_AWP_BoyZ)
alright cool ill check it out
Old Dec 31, 2004 | 12:21 AM
CRX_1.8T's Avatar
Before I removed my system, I just ran all of the wires for the amp and the crossover underneath the carpet on the passenger side(I pulled up the carpet all the way to the back)
. And the RCA's that were coming out of the CD player, I ran those under the center console by pulling the carpet up in the center of the car as well.
Old Dec 31, 2004 | 03:26 AM
Shirk's Avatar
If you have the leather back seat (no compartment) you can use this location:
I have no idea how it looks like back there if you have the security compartment.
You should also ground the head unit to minimize interference and unwanted noise:
Old Dec 31, 2004 | 06:14 AM
type Gendy's Avatar
Default Re: (CRX_1.8T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_1.8T &raquo;</TD></TR><TR><TD CLASS="quote">Before I removed my system, I just ran all of the wires for the amp and the crossover underneath the carpet on the passenger side(I pulled up the carpet all the way to the back)
. And the RCA's that were coming out of the CD player, I ran those under the center console by pulling the carpet up in the center of the car as well.</TD></TR></TABLE>
This is what i did. I ran them soo good i dont wanna pull them out to put the wires in my winter car, and i'm too broke to dish out another ~$80 for wire.
Rev4Ever
24
Mar 13, 2007 06:48 PM
rockin_remz
Audio / Security / Video
May 27, 2006 07:30 PM
ChaosUnbound
Jan 17, 2004 07:41 AM
basshead
17
Jul 22, 2003 03:43 PM
wessieball
30
Mar 19, 2002 06:10 PM
