TRANNY PROBLEM
I HAVE A 92 CIVIC SI WHEN I'M DRIVING AND IM ABOUT TO SWITCH INTO SECOND GEAR AND THE RPM IS HIGHER THAN 4000 RPM IT GRINDS BUT WHEN THE CAR IS COLD LIKE WHEN I JUST TURNED IT ON IT DOESNT DO THAT BUT AFTER A WHILE OF DRIVING IT STARTS TO ACT UP AND I JUST CHANGE THE TRANNY CAUSE THE OLD ONE WAS DOING THE SAME THING SO I WAS WONDERING CAN I GET SOME INFO ON WHAT TO DO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CIVICGEN2 »</TD></TR><TR><TD CLASS="quote">...SO I WAS WONDERING CAN I GET SOME INFO ON WHAT TO DO</TD></TR></TABLE>
stop ******* up your transmissions. learn to shift.
on a real note, try penzoil syncromesh. you can get them at autozone. you need 2 bottles of it (yellow bottles)
If you can't find the Penzoil, use GM Synchromesh friction modified stuff, it should fix that grinding problem.
PS- you may wanna turn your caps lock off.
Chubz
Apr 1, 2005 01:01 PM
