Anybody heard of ZERO FACTORY dyno tuning in TORRANCE, CALIFORNIA?
Old Jan 6, 2002 | 09:44 AM
714eg's Avatar
Default Anybody heard of ZERO FACTORY dyno tuning in TORRANCE, CALIFORNIA?
I took my car yesterday to get tuned and dynoed. My car only made 162.6 to the crank he said. He said that i wasn't even making 150 to the wheels. I have DC 4-1, camsprockets, 2.25 piping running to stock muffler from the axle back, vtec controller, ericks racing ecu, stock intake W/K&N drop in filter, fuel pressure regulator, advanced timing 17. This dyno that they use is old school looking. They put your car on like a regular dyno but the graphs are done using like a earthquake measuring thing. It's wierd. Ijust want to know if there's a trick to reading his dyno sheets. Any help would be appreciated.
Old Jan 6, 2002 | 04:57 PM
Alaniz's Avatar
Default Re: Anybody heard of ZERO FACTORY dyno tuning in TORRANCE, CALIFORNIA? (Teamvizine)
specify what engine is it. I am personal friends with Oshimo.
Old Jan 6, 2002 | 05:58 PM
714eg's Avatar
Default Re: Anybody heard of ZERO FACTORY dyno tuning in TORRANCE, CALIFORNIA? (Alaniz)
I have a B16A2 converted from obd2 to obd1.
Old Jan 6, 2002 | 06:20 PM
Backyard Speical's Avatar
if you want another reading on your motor. you could try JG or R&D, i beleive you'll get more accurate readings. Also they all have great tuners!!!
Old Jan 7, 2002 | 03:14 AM
CivicFerio's Avatar
I was able to squeeze out 152hp or 132whp on my D16Y8 with the help of Oshimo on his bosh dyno... I definitly would recommend him..
Charleston
Old Jan 7, 2002 | 09:55 AM
Katman's Avatar
been they're a few times in the past. Oshimo will be your first Japanese experience if you've never met a real Japanese person before He's way cool. He still wearing his WAKO's race suite?
I dynoed my civic there back in 09/99....
put out 174whp (B17A/CTR pistons/89 B16 head/Spoon intake cam - ITR exhaust/JDM 421 R manifold)
he uses a Bosch dyno which is a bit funkier than a dynojet. He has to calculate certain things once he's done dynoing your car.
Sounds like there might be some issues with your engine.
Stock 89-91 B16A's ususally dyno under or right at 150whp.
[Modified by Katman, 10:56 AM 1/7/2002]
Old Jan 7, 2002 | 10:08 AM
714eg's Avatar
Default Re: Anybody heard of ZERO FACTORY dyno tuning in TORRANCE, CALIFORNIA? (Katman)
My fuel pressure gauge was leaking when we dynoed the car But oshimo didn't notice till the last run. I can't figure out why my fuel pressure gauge is leaking right @ the banjo bolt and the copper washer i torqued it to 18lbs. everybody says to torque it to 16lbs. but it still leaks?
Old Jan 7, 2002 | 10:13 AM
Katman's Avatar
do you have washers on both ends of the banjo fitting?
they're should be 2 washer on that sandwich down on either side of the banjo fitting.
Old Jan 7, 2002 | 12:17 PM
714eg's Avatar
The fuel is leaking out of the washer just above the fuel filter so the one between the banjo bolt and fuel filter the copper washer is what's leaking
Old Jan 7, 2002 | 09:45 PM
Halive's Avatar
New User
civicferio what mods do you have done to your car????
Old Jan 10, 2002 | 01:43 AM
CivicFerio's Avatar
Default Re: Anybody heard of ZERO FACTORY dyno tuning in TORRANCE, CALIFORNIA? (Halive)
I have DC sports 4-1 header, 5 Zigen border muffler, fuel reg, Ir plugs and head work done by http://www.alaniztechnologies.com/
My car in bone stock made 111whp on a dynojet
Plus header and muffler it made 119 on a dynojet
And finally with head work it made 132whp on a bosh dyno with tunning
Charleston
Old Jan 10, 2002 | 05:22 PM
J T*'s Avatar
CivicFerio, what kinda head work did you get done. I have my old D16Y8 sitting im my garage and I'm wanting do so some work to it. just wanting to know what works and what doesn't.
Old Jan 11, 2002 | 11:49 AM
CivicFerio's Avatar
Default Re: Anybody heard of ZERO FACTORY dyno tuning in TORRANCE, CALIFORNIA? (50percentRice)
I got the regular competition head work done by Alaniz... He did some minor porting and did a lot of experimenting on different valve angles that will work best for my head... Probably the only reason I went with this guy is because he has a flow bench and he back his work up with before and after flow numblers...
You can reach Joe Alaniz at http://www.alaniztechnologies.com/ he'll be more than happy to tell with what works and what dosen't...
Charleston
lovey408
Aug 7, 2007 01:35 PM
KOALA YUMMIES
Jul 16, 2005 04:01 PM
98itr0448
Jul 5, 2004 03:08 PM
5thgencivic
Jan 28, 2004 04:30 PM
slimbo
Aug 8, 2002 03:51 PM
