how much juice on a ls/vtec??
Old Dec 24, 2004 | 01:03 PM
boostin4door's Avatar
Default how much juice on a ls/vtec??
whats up i have a fully built ls/vtec from the bottom up basically everything but sleeves.. using stock gsr cams but with a full valve train p&p, je 9:5:1 comp pistons, rings, eagle rods etc..... i was wondering how much of a shot of nitrous i should run on this motot with out having or causing problems i mean ive saw stock ls and or b series motors in general with 75 shot (wet) and they are fine.. i wouldnt do that to a stock motor but how high can i go on this motor i have..... if your going to flame my thread then dont even respond i dont really care what you have to say only the ppl that actually have an idea and or have had or saw a similar set up w/ nitrous please.
Old Dec 24, 2004 | 01:10 PM
.derf.'s Avatar
Default Re: how much juice on a ls/vtec?? (widebodyjaeg16b)
b18a block std bore
gsr crank and rods
je 12.5 to 1 comp pistons
eagle plus size rods
block guard
ported b16 head
buddy club bc4 cams
toda header
ported type r intake manifold
65mm throttle body
rc 310 injectors
car makes over 215whp all motor and is spraying a 150 shot
car has been running with this set up for about 1 1/2 years and is beat on a lot.
car has gone 12.49@108 all motor and 11.29@125 on spray
hope this can help a little
Old Dec 24, 2004 | 02:18 PM
Default Re: how much juice on a ls/vtec?? (.derf.)
sounds good... i wasnt gunan go over 100 but i may just go high comp pistons with some after market cams with like a 50 shot... but i dont beacuse the motor is built already for low comp. i may just go for a 100 shot
Old Dec 24, 2004 | 03:00 PM
nonvtecallmotor's Avatar
With that low CR I would hit that thing hard atleast 150 and go up from there
Old Dec 24, 2004 | 03:09 PM
_entropy's Avatar
Default Re: how much juice on a ls/vtec?? (nonvtecallmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecallmotor &raquo;</TD></TR><TR><TD CLASS="quote">With that low CR I would hit that thing hard atleast 150 and go up from there </TD></TR></TABLE>
Yeah, why the hell hold back? Go get a progressive nitrous controller, if you can make 400+ WHP on stock sleeves with a turbo, why not with juice.
Old Dec 24, 2004 | 05:02 PM
Default Re: how much juice on a ls/vtec?? (@lbert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @lbert &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, why the hell hold back? Go get a progressive nitrous controller, if you can make 400+ WHP on stock sleeves with a turbo, why not with juice.</TD></TR></TABLE>This is true 400hp on juice is possible
Old Dec 24, 2004 | 05:52 PM
yea but for some reason nitrous scares alot of ppl... like its known for blowing **** up... not to say turbo isnt or dosent but nitrous is a whole diff. thing and if not used properly can **** **** up even fully built motors... the only thing im worried about are the sleeves.. you think a block guard would help a little bit?? or should i just just stick it out with the stock sleeves
Old Dec 24, 2004 | 06:59 PM
LSR-Abuser's Avatar
Dude no block guard needed!
He's my set up
B18a stock sleeves
SRP 10.5
Eagle Rods
Ctr Cams
JG Edelbrock manifold
Nos Direct port pro shot {120 shot}
APR Head studs [A must for 100 shot or more]
Runs great! Just Tune it and you will be fine
Old Dec 24, 2004 | 10:59 PM
I would run a block guard in that motor especially since its over bore. Nitrous is safe as long as the tune up is good same thing with a turbo car. I would def. run an EGT gauge it will save your *** if anything does go wrong.
Old Dec 25, 2004 | 01:18 AM
Rusty Shackleferd's Avatar
Ive heard people claiming 250 shot on b series but i dont see how is possible. Theres only so much nitrous you can cram into a motor before is puts out the fire or doesnt gain anymore and is just wasting nitrous.
I had a stock b16 in a ef hatch and started off with
.016 fuel and .024 nitrous went 12.35@110
.018 fuel and .026 nitrous went 12.18@112
.020 fuel and .028 nitrous went 12.13@114 (all using stock 240cc injectors)
I put about 30 bottles threw that motor before i broke the ring lands. The car was all glass and uncut 90 SI hatch with one seat, dash, panels and carpet.
Old Dec 25, 2004 | 01:30 AM
SiKid86's Avatar
Default Re: how much juice on a ls/vtec?? (Rusty Shackleferd)
Widebody can you elaborate on why you went with such a low CR for N/A?
Old Dec 25, 2004 | 06:02 AM
_entropy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rusty Shackleferd &raquo;</TD></TR><TR><TD CLASS="quote">Ive heard people claiming 250 shot on b series but i dont see how is possible. Theres only so much nitrous you can cram into a motor before is puts out the fire or doesnt gain anymore and is just wasting nitrous.
I put about 30 bottles threw that motor before i broke the ring lands. The car was all glass and uncut 90 SI hatch with one seat, dash, panels and carpet. </TD></TR></TABLE>
If you can hammer a 700+ horsepower shot of nitrous into a V8 car, 250 is totally possible on an I4 car. Dave King or somebody else runs a mod motor Ford (4.6L DOHC) in one of his race cars, it only makes like 390 RWHP on motor but he hits it with 650+ horsepower worth of nitrous to be competitive.
Old Dec 25, 2004 | 07:04 AM
Default Re: how much juice on a ls/vtec?? (SiKid86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiKid86 &raquo;</TD></TR><TR><TD CLASS="quote">Widebody can you elaborate on why you went with such a low CR for N/A?</TD></TR></TABLE>
... wasnt going N/A... was going vortech s/c but funds kinda ran short .. so i am just thinking of the easiet way to go a little fast
Old Dec 25, 2004 | 07:41 AM
If you can hammer a 700+ horsepower shot of nitrous into a V8 car, 250 is totally possible on an I4 car. Dave King or somebody else runs a mod motor Ford (4.6L DOHC) in one of his race cars, it only makes like 390 RWHP on motor but he hits it with 650+ horsepower worth of nitrous to be competitive.</TD></TR></TABLE>
Lets say the v8 motor is 5x bigger than our gsr. We have a 100 shot, they have a 500 shot. If we tryed a 250 it would be like them doing a 1250 shot.
Old Dec 25, 2004 | 08:05 AM
yea.. well i mean the motor i have is built to take some abuse... so maybe i will just go with a 100 shot for now see how it reacts or runs... and then go up to a 125 tops... it should still make some good #'s for a daily driver..... if not i am just going to swap the pistons for high CR. and get some stage 2 cams or something.
Old Dec 26, 2004 | 01:11 PM
_entropy's Avatar
Lets say the v8 motor is 5x bigger than our gsr. We have a 100 shot, they have a 500 shot. If we tryed a 250 it would be like them doing a 1250 shot. </TD></TR></TABLE>
5 times? It's a 4.6 litre motor. 2.5 times larger. You should look at it based on nitrous per cylinder, not nitrous per displacement.
Old Dec 26, 2004 | 01:25 PM
cubish's Avatar
i had a 8 fogger set up at one time. this was a gsr motor with 11 to 1 compression and some skunk stage 2's. never ran at the track but i had both set of foggers maxed out. i would spray the first 4 from 1st to 3rd then from 3rd and up i would hit the other 4. so figure each was spraying about 165 plus the motor was making 190hp to the wheels. this was on a stock bore stock sleeve motor. lasted for a pretty long time. i went crazy and added a single fogger and it couldnt take it...
adam00
Mar 1, 2009 08:07 PM
jpnolan
Aug 31, 2008 12:25 PM
iloveb16
Jul 26, 2007 02:35 PM
bootlegtrader
Jun 30, 2005 09:29 PM
