ls/vtec nitrous
Old Feb 22, 2009 | 04:19 PM
adam00's Avatar
Default ls/vtec nitrous
i am thinking about building an ls vtec nitrous i would be using a micropolished and balanced ls crank, shot peened ls rods, (82mm) arias piston, ported b16 head, E85, pro1 cams and a gsr tranny
my question are what would be a good comp ratio to use?
how big of a shot will this motor safely handle on stock sleeves?
and is there anything im missing
Old Feb 22, 2009 | 04:24 PM
integrawow's Avatar
Default Re: ls/vtec nitrous
Make a search for the Nitrous only thread. Best bet for info. Actually, right now, it's only a few posts down in this forum.
Old Feb 22, 2009 | 06:07 PM
adam00's Avatar
i read it but there wasn't really a setup like i want
Old Feb 23, 2009 | 05:15 PM
adam00's Avatar
does anyone have any other input and i was thinking about getting eagle rods
Old Feb 24, 2009 | 03:19 AM
FST GSR 1's Avatar
I am not sure how much power you want to get from spray, but you plan on using a OEM LS crank...not a fan.
All of the last questions could be answered in the "Official Nitrous Thread" if you actually take the time. But since you want the short version...
There are many depending on supporting parts and their quality.
Anything within reason, reason being 50% of your WHP, stock sleeves will be fine.
Yes.
Old Feb 24, 2009 | 05:32 AM
93hondaboy's Avatar
go with eagle rods and forged pistons you will thank yourself later
Old Feb 24, 2009 | 05:44 AM
FST GSR 1's Avatar
I totally missed he wants to use LS rods too...not good, not good at all!
Eagle's aren't really even on my list of rod choices.
Old Feb 24, 2009 | 06:26 AM
adam00's Avatar
dont people make like 600whp+ on stock ls cranks
Old Feb 24, 2009 | 06:35 AM
93hondaboy's Avatar
exactly stock ls cranks there not ls rods. i personally run eagles in my 81 mm with pro3 on spray and the car runs like a bat out hell
Old Feb 24, 2009 | 06:42 AM
adam00's Avatar
how big of a shot are you running? are you using stock sleeves and stock pistons?? and what comp ratio
Old Feb 24, 2009 | 06:49 AM
FST GSR 1's Avatar
Out of what I have actually seen, I saw two LSV motors on big nitrous have crank issues. I am just not a fan for those reasons. I didn't say you couldn't do it.
LS rods won't cut it.
Old Feb 24, 2009 | 06:51 AM
FST GSR 1's Avatar
Hondaboy,
In this thread you are asking for advice on a build that isn't completed:
https://honda-tech.com/forums/showth...119397&page=50
and now you are handing out information based on a build that isn't completed?
Old Feb 25, 2009 | 11:39 AM
93hondaboy's Avatar
actually the build is complete i was only running a simple scenario to see the views and diferent response i would get. but for the most part due to past experiences last year i had a lsv with type head cams and a 130 and it ran damn good. just this year i have decided to set up to the plate and run more nitrous and bigger cams with a done up buttom end. still stock sleeves though im just trying something out though if i have good result sleeved 84 mm coming soon
Old Feb 26, 2009 | 09:57 AM
FST GSR 1's Avatar
Forgot this one boosted...
Old Mar 1, 2009 | 07:19 PM
adam00's Avatar
Old Mar 1, 2009 | 08:07 PM
SilverEk3dr's Avatar
I almost dont see a reason in doing E85. U can just do it like the V8 guys and run a separate fuel system and have it spray c16 through the nitrous. DEF. go direct port. Have it tuned well, and go have fun. I dont see any problem with you spraying 100-150HP shot. Nitrous is fun, but just sucks cause its not there all the time like a turbo.
On my old setup I did just what Im telling you. NX direct port kit on a GSR motor with P30 pistons (11.5:1 c/r) stock rods, arp rod bolts. Had a 100shot, and went low 12's in a teg.
You need to read a LOT more. There is no perfect compression ratio for nitrous. Its just like anything else. U run a big shot, then you need high octane fuel/good tune. Same concept as a turbo only instant Hp.
68cam
11
Feb 2, 2009 04:04 AM
94hatchvx
Jan 25, 2007 03:49 PM
allhonda
Jan 8, 2007 05:47 AM
hondatuner20
Jun 18, 2005 03:59 PM
OEMJDM
Aug 11, 2002 09:37 PM
