Is this setup good for 180whp
I am trying to get 180whp on my 1st gen b16 block with out taking the head off and i was wondering if my setup will get there.
Buddyclub+3
anr header merg coll
skunk2 valve springs and typer retainers
aebs intake mainfold
buddyclub spec2 exhaust with test pipe
hondata s100
anr throttle body
and an hondata intake mainfold gasket
Buddyclub+3
hondata s100
anr throttle body
i dont think a two-layer headgasket will be enough...even with a one-layer gasket, your compression will still be under 11:1, which is the least that you want.
you also stated in your first post that you wanted to achieve 180whp without taking off the head...changing the headgasket would require it. i would suggest going with ctr pistons or milling the head. that is the only way i see you with the higher compression you need.
i mean dont get me wrong, it is possible to get the number you are looking for, but its going to be really tough without compression.
RATED RX-7
13
Mar 25, 2011 04:38 PM
you2envious
May 26, 2002 06:26 PM
