Octane fuel for 13:1
Old Jan 6, 2002 | 12:44 AM
BTR ALL MOTOR's Avatar
Default Octane fuel for 13:1
hey guys, i just finished building my motor and i was wondering if 93 octance fuel should be sufficient for 13:1 compression, or if i need to put octane boost in also. I will be driving this daily so i just wanted to know if pump gas would work, i have heard both sides that it would work fine, and that it wouldnt work......thanks
Old Jan 6, 2002 | 02:12 AM
SpeedracerS4's Avatar
Default Re: Octane fuel for 13:1 (BTR ALL MOTOR)
13:1 daily driven on 93 octane???? i dont think that would work, unless you put race gas or somethin!!
Old Jan 6, 2002 | 02:41 AM
Backyard Speical's Avatar
you might have to run low timming on the streets..... please let me know how it goes.
[Modified by Prodigy 2.2 EK, 11:41 AM 1/6/2002]
Old Jan 6, 2002 | 09:29 AM
nfn15037's Avatar
Default Re: Octane fuel for 13:1 (Prodigy 2.2 EK)
You should be able to pull it off with standalone and some good tuning.
Old Jan 6, 2002 | 04:30 PM
NAB20C5's Avatar
Default Re: Octane fuel for 13:1 (nfn15037)
What pistons?...I run 13:1 on 91-93...w/ dist. timing set @ 16 deg. just watch for pinging and have some one set your timing correctly for you...if you don't know how...check your plugs...after a 1st gear pull and etc. best of luck
Old Jan 6, 2002 | 06:36 PM
976's Avatar
976
New User
Default Re: Octane fuel for 13:1 (NAB20C5)
High compression engine w/ high octane fuel is more prone to detonation. This is what i've learned.
Old Jan 7, 2002 | 04:48 AM
Daemione's Avatar
Default Re: Octane fuel for 13:1 (B21A)
How do you figure?
The whole purpose of high octane is that it's harder to ignite.
Old Jan 7, 2002 | 07:13 AM
3rdShift.org's Avatar
New User
B21A, how did you learn this?
Old Jan 7, 2002 | 02:11 PM
JDM_DOHC_SiR's Avatar
New User
??? SAY What..??!!
Old Jan 7, 2002 | 02:21 PM
sgT's Avatar
sgT
lol. i hope he meant high CR with LOW octane.
And FYI(and for the nth time) octane boosters dont work
Old Jan 7, 2002 | 02:44 PM
freud's Avatar
With the right pistons and headwork 13:1 is easy but you need the right pistons and headwork. A stand-alone fuel magement sytem helps too.
Old Jan 7, 2002 | 02:47 PM
Austin's Avatar
Default Re: Octane fuel for 13:1 (freud)
With good timing and fuel maps you shouldn't have any problems running 13.1:1 on 93 octane...I know of a few people locally that are running high 12:1, low 13:1 on the lovely 91 octane here in California.
Old Jan 8, 2002 | 12:49 PM
Kataku2K3's Avatar
Default Re: Octane fuel for 13:1 (Austin)
Well for 13:1 compression i would hope that you would want to run 93 + a lil octane boost. **** with that C/R i would run at least C14 race gas with ur ignition timing dialed down...
Old Jan 8, 2002 | 12:56 PM
Crazydave's Avatar
Default Re: Octane fuel for 13:1 (JDMspecEG6)
what about water injection?
Old Jan 8, 2002 | 01:12 PM
HX_Guy's Avatar
Default Re: Octane fuel for 13:1 (Crazydave)
C-Speed Racing runs 13.7:1 on 93 octane I believe..but ignition timing is 12 degrees I think.
Old Jan 8, 2002 | 02:07 PM
tinkerbell's Avatar
Default Re: Octane fuel for 13:1 (HX_Guy)
in Australia we get 92(std) and 98(premium) octane fuels.
im not sure if the rating system is the same, but what C/R could be safely run on 98 octane with timing at 16'?
i guess its more than 13:1?
you can also get 100 octane fuel at most tracks over here...but cant run legally on hte street with it.
not sure if this is helping so ill shut up now.
t..
OH YEAH - i all was going to say that octane boosters are a poor supliment for good tuning!!!
[Modified by tinkerbell, 9:09 AM 1/9/2002]
Old Jan 8, 2002 | 03:23 PM
Austin's Avatar
In order for them to run the normal 18 degrees timing all that they would have to do is retard the ignition curve by 6 degrees across the entire map, don't think that it's all that hard with the Hondata.
As I said, with tuning you can do almost anything.
Austin
SoFresh1189
Jan 26, 2010 02:32 PM
hondab18civic
Feb 6, 2006 07:24 AM
PearlWhiteAccord
Dec 11, 2003 12:13 PM
chet
Sep 23, 2003 04:44 PM
wm5holla
Jan 5, 2003 06:59 AM
