Oil Sandwich fitting questions
Does any one have a Greddy oil sandwich kit. Does it use NPT fittings or is it metric? I heard of it have different thread pitch and was difficult to find adapters for oil pressure sensors and oil line fittings...
otherwise, does anyone run a greddy oil pressure gauge with sensor? What size is the sensor and thread pitch? does it fit on the Greddy or GE sandwich???
Greddy likes to use metric threads. It's 1/8" BSPT.
If you want to use a 1/8" NPT adapter or sending unit, then you'll need an adapter.
thanks, do you know anyone that sells the BSPT fittings? I cant find them, only the NPT...maybe im just not looking hard enough..ill try again...thx
PM Flamenco-T. I usually get my 1/8" BSPT (Male) to 1/8" NPT (Female) adapters from Stan. They're $5.50 each the last time I bought them about a month or two ago.
Make sure you don't have any clearance issues with the fittings you plan on using. It can get kind of tight back there.
BlueShadow
Feb 3, 2005 08:27 AM
TAG
Nov 17, 2003 11:13 AM
B18Flip
Jan 9, 2003 10:11 PM
