AutoGage Tach wires
searched and did not find.. got an autogage 10 rev tac for free.. ive had 1 before im just tryin to remember where these wires went. i know blacks ground.. im pretty sure red just goes to a fuse that doesnt have constant power.. does anybody know what wire is the parking light wire so i can wire the white one up 2 it so the light isnt on all the time? and if anybody knows what wire i tap the green on into on the distributor it would be very thankful for a reply.. by the way merry Xmas!
im not sure my car is in the shop,so i cant go check go to there web site and thery will tlell you every thing,but just to let you know i have had a sport comp tach and the autogauge one eveb though there the same company i had way shitty results with the autogauge i just thought i would let you know.
you use the white wie to tap into any light source that will come on when your head lights or on,*note dont use you cigarret lighter like i did,know i have no dash lights and no heater/air controll lights,bad times
well.. tac is hooked up and is working fine now.. but it def wasnt the blue wire to tap into on the dizzy.. when i tapped into it it said my car was idoling at 6000 rpm.. tapped into the yellow wire.. and it works fine
crx_ef8
Mar 10, 2003 10:47 PM
