lsvtec will not start...
Old Dec 23, 2004 | 02:31 AM
dumpeDc2's Avatar
I'm a Jackass
Default lsvtec will not start...
I just finished a lsvtec build I bin working on. Im using a 2000ls block with a 2000b16head im still running the ls ecu obd1. it cranks over and sounds like it wants to start but wont. It has spark and fuel and im still running the stock injectors. what can be the problem???
Old Dec 23, 2004 | 11:52 AM
dumpeDc2's Avatar
I'm a Jackass
Default Re: lsvtec will not start... (integra2103)
anyone
Old Dec 23, 2004 | 04:22 PM
dumpeDc2's Avatar
I'm a Jackass
thanks for the help
Old Dec 23, 2004 | 05:55 PM
dumpeDc2's Avatar
I'm a Jackass
thnks got the help wack-tech I figured it out
Old Dec 26, 2004 | 06:11 AM
B16Civic93's Avatar
what was the problem?
Old Dec 26, 2004 | 01:13 PM
smokie's Avatar
check, timing.valve timing i would check into and ignition timing
Old Dec 27, 2004 | 10:25 AM
99lsvtecauto's Avatar
Default Re: lsvtec will not start... (smokie)
i had a similar problem my lsvtec won't start with my stock ls ecu but will start with my socketed p28 u do need a vtec ecu or at least a vafc to run vtec
Old Dec 27, 2004 | 11:18 AM
t3hatch's Avatar
Default Re: lsvtec will not start... (99lsvtecauto)
I had a similar problem with my b20vtec setup. I don't know where you got your bottom end from, but when I got mine, it was built, but the rings were bad. I checked everything you did first too. Never thought it was the rings, but that turned out to be the problem for me. Hope this might help ya.
Old Dec 29, 2004 | 09:58 PM
silverEG6's Avatar
i had the same damn problem with my LS vtec.. when i got the pistons pressd on they pinched my ring groves cause the rings no to decompress so i couldnt get no compression at all... causing the motor to turn over but not start.
dwayneblanks
Jan 26, 2012 01:49 AM
rsdriver17
May 9, 2008 12:00 PM
skUnK2jdm
30
Feb 7, 2008 04:50 AM
93eg2james
23
Feb 19, 2007 08:05 PM
