Mini Me vtec wiring
you will need to run 3 wires for vtec to work.
1 wire required for vtec soleniod from ecu a4 to vtec soleniod.
2 wire required for vtec pressure switch 1 is from ecu d6 to vtec pressure switch.
the second wire is to ground next to vtec pressure switch or thermostat housing ground.
need more info on wiring you should try to search.
nutball72
Aug 26, 2006 10:54 AM
