Mini Me vtec wiring
Can anyone tell me how to wire my vtec. I just did a mini me swap with a Z6 head and B7 block with a P28 Ecu. Thanks
Re: Mini Me vtec wiring (KY)
you will need to run 3 wires for vtec to work.
1 wire required for vtec soleniod from ecu a4 to vtec soleniod. 2 wire required for vtec pressure switch 1 is from ecu d6 to vtec pressure switch. the second wire is to ground next to vtec pressure switch or thermostat housing ground. need more info on wiring you should try to search. |
