over rev do to miss
Old Dec 22, 2004 | 03:27 PM
hondaeg8's Avatar
Default over rev do to miss
i missed a gear yesterday and the car over reved. it was the first time i have ever done that to this motor. i guess i shouldn't be playing around anymore.
anyways...i was a little worried cause my rpms went above 9k on a stock bottom jdm gsr motor. when i got home, the car wasn't acting any different and it drove home just fine. idle was still the same, idling at 1k and no idle jumping around. temp stayed the same as usual, no smoke out the exhaust, no knocking, oil pressure was reding perfect at idle.
i went a head and did a compression test today and i got 210 across the board.
so everything should be fine right? is there anything else i should do?
thanks
Old Dec 22, 2004 | 06:37 PM
chero112's Avatar
Default Re: over rev do to miss (hondaeg8)
your fine, you was lucky..... lucky tou didn'y bend any valves..... you did a compression test and 210 across the board your fine.....
Old Dec 22, 2004 | 08:09 PM
hondaeg8's Avatar
Default Re: over rev do to miss (chero112)
yeah...it was like 210-212 across the board.
i was just wondering if i would need to do like a valve job or something just to make sure they didn't get out of adjustment or something.
Old Dec 22, 2004 | 09:35 PM
MikeSarr_GSR's Avatar
try and be more judicious on your 3-4 shift. try and pull it down and away from you so you dont hit 2nd. it happens to all of u$ until we learn. have fun and consider yourself lucky
Old Dec 23, 2004 | 12:24 AM
hondaeg8's Avatar
Default Re: over rev do to miss (MikeSarr_GSR)
i didn't put it into 2nd, i just missed 4th.
turned on the car today and listened to the motor. everything sounds pretty good.
Old Dec 23, 2004 | 01:36 AM
OLM-02R's Avatar
210 sounds alright...
Old Dec 23, 2004 | 09:06 AM
hondaeg8's Avatar
Default Re: (OLM-02R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OLM-02R &raquo;</TD></TR><TR><TD CLASS="quote">210 sounds alright... </TD></TR></TABLE>
yeah...i did a compression test like 4-5 months ago and i got 210 back then also across the board.
Old Dec 23, 2004 | 11:00 AM
AlLMoToRvOtEr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 &raquo;</TD></TR><TR><TD CLASS="quote">i missed a gear yesterday and the car over reved. it was the first time i have ever done that to this motor. i guess i shouldn't be playing around anymore.
thanks
Come on you sissys, My bone stock USDM GSR got shifted at like 8900 every gear everytime I was track and the motor was just fine. The only time you really have to worry is if it went over 10K then you will bend some valves. Don't even worry about it the motor will be perfectly fine. Have fun................
Old Dec 23, 2004 | 01:24 PM
hondaeg8's Avatar
i know it hit at least 10k, could have gone over, don't know.
Old Dec 23, 2004 | 01:37 PM
rev limiter's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 &raquo;</TD></TR><TR><TD CLASS="quote">i didn't put it into 2nd, i just missed 4th.
turned on the car today and listened to the motor. everything sounds pretty good.</TD></TR></TABLE>
I don't understand. If you just missed 4th how the hell can you over rev ?? I mean than the car is neutral and at wot so you just bouns of the rev limiter so you can't over rev ???
Old Dec 23, 2004 | 02:46 PM
Default Re: over rev do to miss (rev limiter)
He obviously has a chipped ECU smart guy and prolly was power shifting. Not to many people have factory ECU's with rev limiters
Old Dec 23, 2004 | 03:09 PM
-iLLuZioN-B18C1's Avatar
if everything seems fine, sounds fine, compression is good. i wouldnt worry to much about it. ive done it a few times with mine and never had a problem.
Old Dec 24, 2004 | 01:59 AM
Default Re: over rev do to miss (AlLMoToRvOtEr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlLMoToRvOtEr &raquo;</TD></TR><TR><TD CLASS="quote">He obviously has a chipped ECU smart guy and prolly was power shifting. Not to many people have factory ECU's with rev limiters</TD></TR></TABLE>
power shifting is oke but you got to have a rev limit
Old Dec 24, 2004 | 07:57 AM
LSVTEC 91 Civic's Avatar
Banned
You need this...
http://store.summitracing.com/...01138
Works great, I have one... A lot safer than cutting fuel.
Old Dec 24, 2004 | 11:45 AM
DaVinci's Avatar
Default Re: over rev do to miss (LSVTEC 91 Civic)
no need to worry. stock bottom end can handle it on occasion. however, a soft touch rev limiter would be cheap insurance.
Old Dec 27, 2004 | 10:50 AM
Default Re: over rev do to miss (DaVinci)
haha i have one built into my msd digital 6
Old Dec 27, 2004 | 12:39 PM
SD1222's Avatar
u should be okay. Like u said it only happen once.
Old Dec 27, 2004 | 02:21 PM
Default Re: over rev do to miss (jdm_spoonEG)
Can some one explain how people over rev when they miss shift. So from third to fourth and just miss it NOT come in second. If everything is oke you should just bounce off the rev limiter, right ???
Old Dec 27, 2004 | 04:38 PM
B18civicsi00's Avatar
How long was it over 9k. If it is less then 2-3 sec you should be all good
Old Dec 27, 2004 | 05:44 PM
JoeB18R's Avatar
Default Re: over rev do to miss (B18civicsi00)
id be more concerned with the valve train binding (springs) or a valve bending VS worrying about the engine internals. If you dont hear any valvetrain noise (clicking or ticking), and you dont see any smoke exiting the exhaust, I wouldnt worry about it.
Old Dec 27, 2004 | 08:17 PM
ek9poorR's Avatar
you need to stop messing around!!!
better yet stop smoking that *****.....its making you paranoid...aol..lol
on the real your okay but be carefull next time cuz my friend just bent a valve a week ago...due to mishift..... and its not pretty when you bent a valve...
Old Dec 27, 2004 | 11:56 PM
hondaeg8's Avatar
Default Re: over rev do to miss (ek9poorR)
i'm sure it hit 10k, but it was for like 2 seconds or so. right when i mis shifted, i let off the gas so its not like i left the rpms up at 10k for a period of time.
i did a compression test and the numbers came out good. i hear no valve train noise either. my oil pressure is still good also.
my friend bent like 6 valves when he missed a gear, so i know what a car sounds like with bent valves and my car doesn't sound like that.
i wasn't too concerned about bent valves, i was more concerned about my block.
i would rather have bent valves than a spun bearing.
good think everything is okay though. i will stop messing around
Old Jan 6, 2005 | 07:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rev limiter &raquo;</TD></TR><TR><TD CLASS="quote">Can some one explain how people over rev when they miss shift. So from third to fourth and just miss it NOT go into second. If everything is oke you should just bounce off the rev limiter, right ???</TD></TR></TABLE>
Still like to know how this is possible ???
chancek
Nov 4, 2010 10:58 AM
phateless
Mar 24, 2010 02:15 PM
hondaeg8
13
Dec 23, 2004 09:05 AM
Modifiedinteg
Oct 17, 2003 04:58 AM
1fast5gp
Mar 22, 2003 01:58 PM
