loss motion esembly
Old Oct 16, 2003 | 08:02 PM
Modifiedinteg's Avatar
Default loss motion esembly
can you change out the lost motion esmebly with the head still on the car?
i have this valve tic and its annoying as hell!!!!!!! what happen was i was racing and i shift from 3rd back into 2nd and i dont know what the hell rpms i was at. but i did a compression test and they are around 173-180 psi and i all so did a leak down test and have 0-1 percent leak on all 4. and the last thing i did was a vavle ajustment. i just found out if the lost motion esembly is bad it would tic loud. so what would you guys sugest????
Old Oct 16, 2003 | 08:27 PM
Default Re: loss motion esembly (Modifiedinteg)
any one out there
Old Oct 16, 2003 | 08:28 PM
P1mpSlap's Avatar
I believe you do have to pull the head.
Not to mention it'll make work 100000 X easier.
Old Oct 16, 2003 | 08:45 PM
Default Re: (P1mpSlap)
do you know what that tic might be. if it was a bent valve wouldnt feel like it had a misfire under load or at idle?
Old Oct 16, 2003 | 09:33 PM
Muckman's Avatar
Moderator in Chief
Ive totally ripped apart engines and put them back together and ive never heard of a loss motion assembly. what the hell is it?
Old Oct 16, 2003 | 09:57 PM
Cole D's Avatar
Default Re: (Modifiedinteg)
if its a lost motion assy the ticking is constat at idle and normal hwy driving. It doesn't go away until you hit vtec a quick test remove the valve cover bring each cylinder up to tdc just like you would do if your doing a valve adjustment. The rocker arm in between the valves is where your lma is located push that down if it comes back up smoothly then its good but if it comes up slowly or kinda of sticking then that's your problem you have 8 lma's in the head. Hop this helps
Chris
Old Oct 16, 2003 | 09:59 PM
Cole D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Modifiedinteg &raquo;</TD></TR><TR><TD CLASS="quote">do you know what that tic might be. if it was a bent valve wouldnt feel like it had a misfire under load or at idle?</TD></TR></TABLE>
Bent valve....... no you would notice a huge decrease in power before the car shut off
Old Oct 16, 2003 | 10:01 PM
Cole D's Avatar
Default Re: (Muckman)
I would be scared if you worked on my engine j/k
Old Oct 16, 2003 | 10:12 PM
Newman's Avatar
New User
You need to remove the rocker arms and valve springs & retainers to get them out. Use ITR LMAs as they are better than the B16A LMAs. I've seen some LMAs collapse, causing the cam to snap into pieces. If you plan on revving the motor high, and have some high profile cams and good valve springs & retainers, upgrade the LMAs to ITR ones.
Old Oct 16, 2003 | 10:30 PM
Rob Dizzle's Avatar
Default Re: loss motion esembly (Newman)
I am not sure about having to take the rocker arms out. it didnt seem like it was necessary when I last looked at a head with the cams out, but i could be wrong.
i do know that the lma's can be taken out when the head is on the car
Old Oct 17, 2003 | 04:58 AM
mr.beeks's Avatar
Default Re: loss motion esembly (Bob-DC2)
whats the price for ITR's lost motion assembly?
*** far as I know you take the cams and the rockers in order to change them
there is no need to take the spring and retainers out for this
change. and how a bad motion assembly going to break your cams?
JMod
Oct 24, 2005 08:31 PM
hondaeg8
22
Jan 6, 2005 07:37 AM
Carbon_Lude98
Oct 18, 2004 06:19 AM
JdmIntegra98
Jul 3, 2003 03:58 PM
1fast5gp
Mar 22, 2003 01:58 PM
