TEIN camber plates
Old Dec 22, 2004 | 08:47 AM
Burgh's Avatar
Default TEIN camber plates
What the hell is this? I didn't even think that the older civics could use camber plates. Would be interesting to see if these work for the EP3/DC5 though.
http://cgi.ebay.com/ebaymotors...=true
Old Dec 22, 2004 | 12:56 PM
f1nal zeros's Avatar
Default Re: TEIN camber plates (Burgh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burgh &raquo;</TD></TR><TR><TD CLASS="quote">What the hell is this? I didn't even think that the older civics could use camber plates. Would be interesting to see if these work for the EP3/DC5 though.
http://cgi.ebay.com/ebaymotors...=true</TD></TR></TABLE>
You can get these for the DC5/EP3. You can buy them seperatly for around 200 or so. You can use these for the SS and up versions.
Old Dec 22, 2004 | 09:05 PM
PhunDrm's Avatar
I've got em on my Tein SS-P's. Yes they'll work. I haven't had mine aligned yet. The camber in the front looks alright. The rear camber is off by about -4 degrees. lol.
Old Dec 24, 2004 | 09:46 AM
johnkimble's Avatar
camber kits like that = the ****
Old Dec 25, 2004 | 11:56 AM
Boilermaker1's Avatar
Anyone know the diameter of the hole through the mount? Can they be used on top of Konis or stock struts as well?
EDIT... these are add-on plates to things like the SS which use the stock upper mounts yes? I think I'm going to answer my own question, they will fit since the nut that goes on top has to be the same size.
Old Dec 25, 2004 | 12:28 PM
Halo's Avatar
Default Re: (Boilermaker1)
I wonder if you can use these with any shock or exclusively with tein?
Old Dec 25, 2004 | 12:29 PM
Halo's Avatar
Default Re: (johnkimble)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnkimble &raquo;</TD></TR><TR><TD CLASS="quote">camber kits like that = the **** </TD></TR></TABLE>
what is your logic?
Old Dec 25, 2004 | 01:03 PM
johnkimble's Avatar
camber kits with that design even on different chassis inside the fenderwell or inside the engine bay are very simple to adjust. this is opposed to say SPC style kits out there. this would be the only style camber kit I would ever run again (not using a camber kit right now, but i've had spc style kits in the past) but if I was in the market to run a kit it would definately be something like this tein or preferably the BC coilovers come preassembled with a similar setup for the dc5/ep3 platform.
Old Dec 25, 2004 | 06:07 PM
Default Re: (Halo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Halo &raquo;</TD></TR><TR><TD CLASS="quote">I wonder if you can use these with any shock or exclusively with tein?</TD></TR></TABLE>
The one thing I did notice is that Tein uses 70mm ID springs (thats 2.7") which aren't really standard. If the upper spring seat isn't built into the bottom plate of the pillowball, then yeah, you probably can use any upper seat you want, but if it is built in, you'd have to machine down the seat to 2.5" or whatever ID springs you got so you could use them.
I'm gonna call monday and find out, I'd like to know myself.
Old Dec 29, 2004 | 11:14 AM
A D NOH's Avatar
I really don't know
Community Builder
Buddy club has a similar version to this as well. not so great for reducing camber though
From what i recall it also changes caster a slight bit. take that with a grain of salt though
hondapunkrock
Jul 21, 2008 07:34 AM
i0o0ll0o0i
May 31, 2006 12:21 AM
VtecBlissS2k
Honda S2000
24
Feb 17, 2005 06:25 AM
tgrace
Jan 15, 2004 03:42 PM
FlaN.
Nov 5, 2003 11:39 AM
