Tein suspension
Old Nov 2, 2003 | 06:56 PM
FlaN.'s Avatar
Default Tein suspension
hey guys. for those of you who have tein s.s./flex coilovers. are you guys using camber kits? what will be an acceptable setting w/o using a camber kit. i bought a bunch of other stuff for my car and forgot to buy a camber kit so it'll be a couple of weeks. i'm not waiting either because i'm tired of it, im puttin them on tomorrow. thanks.
Old Nov 2, 2003 | 09:12 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: Tein suspension (theJUMPoff)
just get a proper alignment. toe-in is what really causes tire wear...well EXCESSIVE camber too...i mean excessive. i have HAs...and I've been running with the same setup for almost 2 years..adjusted the height a couple of times... still been lazy to get another alignment. ive got camber (skunk2 camber kit is waiting to be put on), but the toe-in is what's wearing out my tires right now.
NRG
Old Nov 2, 2003 | 10:23 PM
integraL's Avatar
Default Re: Tein suspension (NightRider-gsR)
an align is what can solve the toe problem right?
Old Nov 3, 2003 | 05:44 AM
FlaN.'s Avatar
Old Nov 3, 2003 | 02:16 PM
In-N-Out Burger
Default Re: Tein suspension (integraL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraL &raquo;</TD></TR><TR><TD CLASS="quote">an align is what can solve the toe problem right?</TD></TR></TABLE>
You are correct sir!
NRG
Old Nov 3, 2003 | 03:29 PM
babes 99 GSR's Avatar
About how much does it cost to get the car aligned? I just put on some zeal b6s and should probably have that done since i'm pretty happy with the current height...
-Staci
Old Nov 3, 2003 | 03:32 PM
[ iLL ] iNt3GrA's Avatar
neg camber would cause the inside of the tire to wear depending on how neg it is is how fast ur gonna need a new set of tires
Old Nov 3, 2003 | 04:05 PM
In-N-Out Burger
Default Re: Tein suspension (0nL1ne)
$100? what a rip off....$60 sounds about right.
NRG
Old Nov 3, 2003 | 06:25 PM
FlaN.'s Avatar
100 bucks, pffsh. 50 around here, which isn't too bad considering most places won't touch a lowered car in my area too.
Old Nov 5, 2003 | 10:53 AM
smiko0124's Avatar
Default Re: (theJUMPoff)
got ya all beat... 34 bucks y0... Northern Indiana fo shizzy
Old Nov 5, 2003 | 11:01 AM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: Tein suspension (99GSR1980)
It cost me $60 to get my car aligned. $100 is a ripoff. Just get an alignment and you will be fine.
&lt;------------ Is rolling with -2f/-1.2 deg camber for 10k and gets even tire wear
Old Nov 5, 2003 | 11:39 AM
dave12285's Avatar
It all depends on how low you set the Tein's for. My ss's are set pretty low and i have a camber kit front and rear along with an alignment. A small amount of camber can deff be your friend but if the toe settings are not correct it could cause poor handling, unsafe steering, and excessive tire wear. hth.
cortrain
Suspension & Brakes
May 29, 2008 10:40 PM
masaaki86
Feb 27, 2007 05:55 AM
tgrace
Jan 15, 2004 03:42 PM
Wiseguy619
Dec 8, 2003 09:55 AM
