how much is the labor installation of block
Old Dec 22, 2004 | 12:45 AM
yeegsr's Avatar
Default how much is the labor installation of block
how much does it cost for labor to install "higher compression pistons, rings, rods, block guard"
i just want to know the labor cost, let says installing everythign at once
Old Dec 22, 2004 | 04:57 AM
Surubasi00's Avatar
Default Re: how much is the labor installation of block (yeegsr)
block guard is a dseries thing, not used so much in b series...call a shop. ask around, never underestimate the power of a phone book and google
Dave
Old Dec 22, 2004 | 05:57 AM
Chillinit's Avatar
Default Re: how much is the labor installation of block (Surubasi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Surubasi00 &raquo;</TD></TR><TR><TD CLASS="quote">block guard is a dseries thing, not used so much in b series...call a shop. ask around, never underestimate the power of a phone book and google
Dave</TD></TR></TABLE>
block guards are a d-series thing? what are you smokin holmes?
Old Dec 22, 2004 | 07:03 PM
yeegsr's Avatar
Default Re: how much is the labor installation of block (Chillinit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit &raquo;</TD></TR><TR><TD CLASS="quote">
block guards are a d-series thing? what are you smokin holmes? </TD></TR></TABLE>
Im not sure what he meant by that either....
im talking about B-series labor here...
Old Dec 22, 2004 | 07:11 PM
volcom40street's Avatar
I want to know as well. I'm in the process of the same thing.
Old Dec 22, 2004 | 08:04 PM
asubennett's Avatar
Default Re: how much is the labor installation of block (volcom40street)
So many variables.
Experience and Expertise of the shop.
Is the block already prepped? I.E. Bored and Honed
Do you need the pistons pressed onto the rods?
DO you need the old rod bolts pressed out and new ones pressed in?
Do you need the rotating assebly zero balanced?
Answers these questions and we can provide a better guesstimate.
Old Dec 23, 2004 | 10:38 PM
IntegraLs14sedan's Avatar
Default Re: how much is the labor installation of block (asubennett)
hey watsup all....i'm actually in the proccess of rebuilding my block right now. i have a b18b1. its gonna cost me $850, but thats with me taking the block out and bringing it to the machine shop. i'm going with OEM oversized ITR pistons&rings which cost $200, all new bearings which cost roughly $120, and a complete gasket set for $200. the rest is labor to disamble & reasemble the block ($120), pin the pistons and align the rods ($36) , boring the sleeves ($80) , and steam clean ($48). i don't plan on reving any higher than 6800rpm so i didn't balance the crank which would of cost $125 dollars more. well i hope this give you an idea of the cost.
Old Dec 24, 2004 | 09:07 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">So many variables.
Answers these questions and we can provide a better guesstimate. </TD></TR></TABLE>
theyre better be an expertise to do this shesh...here:
disassemble the motor block, old rods out and pressed new rods in, no bored or honed, yes..rotating assebly zero balanced and install the pistons, measured piston to wall clearance.... reassemble block...
Old Dec 25, 2004 | 02:07 PM
Surubasi00's Avatar
im sayin that i have seen them a lot more on D series than b series, thats all
Dave
Old Dec 26, 2004 | 03:56 AM
asubennett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr &raquo;</TD></TR><TR><TD CLASS="quote">
disassemble the motor block, old rods out and pressed new rods in, no bored or honed, yes..rotating assebly zero balanced and install the pistons, measured piston to wall clearance.... reassemble block...</TD></TR></TABLE>
Dissasemble- Does this mean you are bringing him a bare shortblock?
Press pistons off of Rods $10
Press New pistons on Rods- $20
Zero Balance rotating assembly- $100
Reassemble block- (Totally depends on the expertise of the builder) $100-$300.
Old Dec 26, 2004 | 12:49 PM
Copy Cat's Avatar
in maryland the most charge around 500-600 bucks for a regular build(if you supply parts), meaning disassembling everything, boreing out the walls, balancing rotating and reinstallation. Ive seen some shops around here charge as much as 1800 bucks though which seems way to much for a rebuild if you ask me.
Old Dec 26, 2004 | 02:34 PM
yeegsr's Avatar
Default Re: how much is the labor installation of block (CivicFerioViRs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicFerioViRs &raquo;</TD></TR><TR><TD CLASS="quote">in maryland the most charge around 500-600 bucks for a regular build(if you supply parts), meaning disassembling everything, boreing out the walls, balancing rotating and reinstallation. Ive seen some shops around here charge as much as 1800 bucks though which seems way to much for a rebuild if you ask me.</TD></TR></TABLE>
that was some serious deal man, for 5bills to 6bills. No ones can beat that.
Old Dec 26, 2004 | 10:20 PM
Copy Cat's Avatar
yea seriously, im really happy to live in maryland how much do people charge in your area? im kinda torn between three shops. jim justice, ben shaffer, or burtonsville performance. i have heard good things about all.
Old Dec 27, 2004 | 05:05 AM
4drsedaneg's Avatar
i just had my h22 done, it worked out like this
i gave him
bare block
old pistons and rods(togeather)
crank
flywheel
pully
new type s pistons and rings
wash block- $30
polish+ wash crank $45
balance rotating assembly $200
hone frm $70
deck block $80
rebush rod for floating pins $140
assemble rods+piston $50
gap and install rings $45
the bronze bushings were $30
and i had him get me arp main studs $106
total was $815.06
jdm_SirG
Aug 27, 2006 06:46 PM
GoneToTheDarkSide
Dec 15, 2005 04:52 PM
Linus_E
Mar 23, 2005 04:52 AM
ITR97-143
Jul 23, 2004 04:16 PM
