Is displacement just bore and stroke?
Old Dec 21, 2004 | 10:12 PM
OEMcivic's Avatar
Default Is displacement just bore and stroke?
I was using the C-speedracing calculator to find compression and I noticed the displacement changed when I changed the gasket thickness, piston to deck clearance, or head cc. Why is this?
Old Dec 21, 2004 | 10:15 PM
Mike K's Avatar
Default Re: Is displacement just bore and stroke? (OEMcivic)
according to vehicle manufacturers, displacement is strictly bore and stroke, but when you get more internal and start to build engines, you get more variables.
so basically, your 1797cc GSR might actually be 1799.4cc or whatever.
Old Dec 22, 2004 | 02:21 AM
NJIN BUILDR's Avatar
You are right,displacement is bore and stroke only.They went out so many decimal point its probably a rounding error in the program.
Glenn
Old Dec 22, 2004 | 04:58 AM
Lsos's Avatar
I used a calculator like that, too (might have been the same one), and saw the same problem. It is wrong. Those other variables don't affect displacement.
Old Dec 22, 2004 | 07:52 AM
Wes V's Avatar
Default Re: Is displacement just bore and stroke? (Lsos)
Displacement is just a function of bore and stroke!
Compression is more complex and would include head volume, volume at the head gasket, and displaced volume of the piston top and how high it goes into the head volume (deck height).
Wes.
Old Dec 22, 2004 | 11:25 AM
aj99si's Avatar
Default Re: Is displacement just bore and stroke? (Wes V)
I meant to say chamber volume would increase by adding a thicker gasket
Modified by aj99si at 11:21 AM 12/26/2004
Old Dec 22, 2004 | 11:28 AM
tk's Avatar
tk
Bore x bore x stroke x # of cyls x .7854 = displacement
Head gskt changes compression not cubic inch
Old Dec 22, 2004 | 03:45 PM
Lsos's Avatar
Default Re: Is displacement just bore and stroke? (aj99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aj99si &raquo;</TD></TR><TR><TD CLASS="quote">If you add a thicker head gasket you increase the displacement of the engine </TD></TR></TABLE>
You can add fifty head gaskets and the displacement won't change.
Old Dec 22, 2004 | 06:08 PM
RMF
Guest
Posts: n/a
Default Re: Is displacement just bore and stroke? (tk)
Or for a 4 cyl. its...... bore x borex3.14x stroke=
Old Jan 5, 2005 | 08:18 AM
climbengruven's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lsos &raquo;</TD></TR><TR><TD CLASS="quote">
You can add fifty head gaskets and the displacement won't change.</TD></TR></TABLE>
lol umm...yes bob for 1000 plz, it will change.
displacement is bore and stroke, the distance from TDC to BDC the piston travels. As mentioned before with the cylinder volume, thats going to effect the compression ratio rather than the displacment as that will be a fixed variable.
Diesel engines have a higher compression ratio bcuz they have a lower head volume bcuz they dont need the clearence for a spark plug....hence the piston can get right up there and compress the gas/fuel more
Old Jan 5, 2005 | 08:20 AM
Default Re: Is displacement just bore and stroke? (lococlimbermonkey)
nevermind.. i agreed with the post before lol... if ya add 50 head gaskets, the displacment wil be the same yes, but the compression ratio will suck *****
WorrGame13
Mar 30, 2007 03:35 PM
drunknbass
Aug 18, 2004 08:21 PM
b00stedbyFastrax
Dec 24, 2003 05:58 PM
Rob Dizzle
May 30, 2003 11:31 PM
