converting OBD-2 engine to OBD-1
Old Dec 21, 2004 | 10:07 PM
BeavisB16's Avatar
Default converting OBD-2 engine to OBD-1
I know the distributor has to be OBD-1. Is there a difference between VTEC and non VTEC distributors? The ECU has to be OBD-1 as well. Is that all there is to it?
Old Dec 21, 2004 | 10:10 PM
Legendaryyaj's Avatar
Default Re: converting OBD-2 engine to OBD-1 (BeavisB16)
You need to switch the intake mani too i believe.
Old Dec 21, 2004 | 10:14 PM
BeavisB16's Avatar
Default Re: converting OBD-2 engine to OBD-1 (Legendaryyaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legendaryyaj &raquo;</TD></TR><TR><TD CLASS="quote">You need to switch the intake mani too i believe.</TD></TR></TABLE>
Ok, I've never heard that one. Can anyone else verify?
Old Dec 21, 2004 | 10:21 PM
Its something about OBD1 having only 1 i think IAV(something like that) and OBD2 having 2 or the other way around.
Old Dec 21, 2004 | 10:28 PM
BeavisB16's Avatar
Couldn't it just be plugged or something?
Old Dec 21, 2004 | 10:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeavisB16 &raquo;</TD></TR><TR><TD CLASS="quote">Couldn't it just be plugged or something?</TD></TR></TABLE>
I have no idea. I started to look into this when i had my 4banger but now that i got a V6 i didnt go any further. I do know you have to do something with the intake mani. though. Sorry I couldnt help ya out much.
Old Dec 21, 2004 | 10:35 PM
BeavisB16's Avatar
thanks for your help
BUMP for more information
Old Dec 22, 2004 | 05:57 AM
BeavisB16's Avatar
I have been reading more and more about the OBDII to OBD1 conversion problem, it looks like a conversion harness will take care of everything, plus OBDI ECU. Can anyone help me confirm this applies to F22's as well?
Old Dec 23, 2004 | 06:28 AM
SpeedFreak77's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeavisB16 &raquo;</TD></TR><TR><TD CLASS="quote">I have been reading more and more about the OBDII to OBD1 conversion problem, it looks like a conversion harness will take care of everything, plus OBDI ECU. Can anyone help me confirm this applies to F22's as well?</TD></TR></TABLE>
from what I have read you are right but the fuel injectors also need to be replaced. That may have been what you were thinking about on the intake manifold.
Old Dec 23, 2004 | 08:02 AM
notoriousB's Avatar
Default Re: converting OBD-2 engine to OBD-1 (SpeedFreak77)
it's not the injectors, it's the IACV. OBD2 accords have a 3-wire IACV but OBD1 computers need a 2-wire IACV. You can change the IM or make an adapter plate to attach the 2-wire IACV to your IM. Then you have to wire the 2-wire IACV in.
Old Dec 23, 2004 | 10:56 AM
Default Re: converting OBD-2 engine to OBD-1 (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">it's not the injectors, it's the IACV. OBD2 accords have a 3-wire IACV but OBD1 computers need a 2-wire IACV. You can change the IM or make an adapter plate to attach the 2-wire IACV to your IM. Then you have to wire the 2-wire IACV in.</TD></TR></TABLE>
Thank You Thank You.
QBANBOY407
Honda Civic (2001 - 2005)
20
Oct 9, 2007 08:28 PM
Trademark
Aug 15, 2006 11:19 PM
Vtak DOHCTA
Jul 19, 2006 06:18 PM
crxowner
Mar 11, 2006 06:28 PM
firstgenrex
Dec 21, 2003 05:02 PM
