Car will NOT start - slowly died on the freeway...
Old Dec 21, 2004 | 07:03 PM
erikiksaz1's Avatar
Default Car will NOT start - slowly died on the freeway...
I was driving on the freeway, the car stuttered for a bit, and it seemed as if i had lost all power (as if i was in neutral), even though i was able to rev the car for a bit before i eventually shut it off. It now cranks, but will not turn over.
So far there's spark, but i don't know if it's adequate. A screwdriver was stuck into the spark plug and placed near a ground--and it arc'ed.
As for fuel, the fuel pump turns on, you could hear it through the gas door. And if the fuel pump were a problem, i don't think i'd be able to rev the car when it was in the process of slowing down.
Compression - compression was tested to be alright about a year ago, but who knows now.
Air - all good.
Anyways, i noticed a few months ago that there was a squeaking noise coming from the distributor. It would make the noise sporadically. Now, i'm thinking it'd be the bearings, but i've heard that you'll see red dust or whatnot in the cap if the bearing has gone out. But, the car is still sparking...
So what do you guys think?
Old Dec 21, 2004 | 07:14 PM
89 crix si's Avatar
Default Re: Car will NOT start - slowly died on the freeway... (erikiksaz1)
my car did the same thing on the highway, i took off the distributor cap and saw that the rotor inside had come unscrewed.....i screwed it back on and it started right up. hope this helps.
Old Dec 21, 2004 | 07:26 PM
erikiksaz1's Avatar
Default Re: Car will NOT start - slowly died on the freeway... (89 crix si)
Well, i opened up the cap the day it broke down and everything looked to be fine. I didn't see any discoloring, dust, or anything out of place at all.
Old Dec 21, 2004 | 07:28 PM
89 crix si's Avatar
did it backfire at all? cuz my friends hatch died, and everything looked fine but the distributor needed to be replaced. good luck man.
Old Dec 21, 2004 | 07:32 PM
raeanin's Avatar
slow power die... ive had that happen and it was a blown head gasket but that might not be your problem.. just somthing to look into
GsO Redneck
Sep 7, 2012 10:13 AM
Seatown
Nov 14, 2006 06:51 AM
PETEROCK1
14
Jul 19, 2005 06:55 AM
Daniel_san
18
Apr 26, 2004 06:24 AM
MysteryWagon
13
Apr 15, 2003 01:14 PM
