how do i tighten my belts.
Old Dec 21, 2004 | 12:32 PM
92hondalude's Avatar
Default how do i tighten my belts.
when i take out my ac compressor out of my h23 i need to know how i tighten the belt from the altonator to the crank
Old Dec 21, 2004 | 09:47 PM
Mike K's Avatar
Default Re: how do i tighten my belts. (92hondalude)
so you're removing your compressor or replacing it?
if you're replacing it, then you need to properly evacuate and recharge the system, then it should be a no brainer as far as the belt.. tension it the same way you released the tension on the oe belt before you removed the compressor.
if you're straight up REMOVING your a/c.. that's a different story. i've never dealt with that, but isnt the tensioner for the belt on the compressor BRACKET and not the actual compressor? if so, with a shorter belt, you should still be able to use the tensioner.
sinister357
Jul 28, 2007 06:36 PM
DBAl
Jul 20, 2006 09:17 AM
BBuncky2
Jan 10, 2006 11:48 AM
vbajmani
Dec 7, 2005 09:21 PM
BlackGS-R
Aug 11, 2004 05:15 PM
