engine leaking need help
Old Dec 21, 2004 | 10:48 AM
BANting's Avatar
Default engine leaking need help
I have oil leaking between my block and oil pan is it for sure my oil pan gasket? Is changing your oil pan and gasket hard? and is there any write ups on it?
Old Dec 21, 2004 | 03:07 PM
vtec94civic's Avatar
i don't know if there are any write ups but it is very easy to do. first remove the two tranny support brackets. second remove the flywheel cover plate. third remove all the 10mm nuts and bolts that go around the oil pan. then once you do that just pry off the pan.
Old Dec 21, 2004 | 04:34 PM
eda6's Avatar
Default Re: (vtec94civic)
https://honda-tech.com/zerothread?id=248222
I remember removing the heder when i changed my oilpan gasket.
Old Dec 21, 2004 | 06:53 PM
^^^ oh yeah forgot about the header.lol
Old Dec 21, 2004 | 07:17 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec94civic &raquo;</TD></TR><TR><TD CLASS="quote">i don't know if there are any write ups but it is very easy to do. first remove the two tranny support brackets. second remove the flywheel cover plate. third remove all the 10mm nuts and bolts that go around the oil pan. then once you do that just pry off the pan.</TD></TR></TABLE>
simple as that including removing the header
Old Dec 21, 2004 | 08:26 PM
BANting's Avatar
Default Re: (sleeperciv)
alright thanks for the everyone
civicSF98
Jul 20, 2009 09:24 AM
wdissident
Jan 19, 2009 08:49 PM
sony224422
Feb 3, 2007 04:16 PM
Loveless
Apr 23, 2003 04:57 PM
joefuni
Dec 3, 2002 03:30 PM
