changing oil pan
Old 12-03-2002, 10:56 AM
New User
joefuni's Avatar
Default changing oil pan
hey i searched and couldnt find anything but im about to change my oil pan because i cracked it. i have the gasket, new pan, oil, filter, and all necessary tools. anything i should be aware of before i do this? is there a certain order to tighten the bolts down? thanks
Old 12-03-2002, 03:04 PM
nd8ch's Avatar
Default Re: changing oil pan (joefuni)
most people recommend honda-bond...kinda expensive
sorry, i dont remember about bolt patterns
Old 12-03-2002, 03:10 PM
Slurp56's Avatar
I just changed one 2 days ago
The bolts get torqued to 10lbs.
Remove your header first (remember to unplug that O2 sensor before dropping the header). Then remove (2) 17mm bolts on the tranny brackets. Then remove the (5) 12mm bolts, 3 of them are on the tranny brackets, the tranny brakets will then fall free, 2 of them are on the flywheel cover bottom. Next remove (2) 10mm bolts and the flywheel cover will fall off. Next drain the oil and remove all of the 10mm bolts and nuts that fasten the pan to the bottom of the block. Then remove the pan and old gasket, scrape where the gasket seals on the block to get rid of any left over liquid gasket. Then install the new gasket on the new pan and reinstall in reverse order. Torque the oil pan bolts to 10lbs of torque. Reinstall the flywheel cover and tranny brackets, then the header and remember to plug in the O2 sensor. Change oil filter, fill engine with oil and drive
Old 12-03-2002, 03:30 PM
t0p_sh0tta's Avatar
Default Re: changing oil pan (Slurp56)
i don't have my helms with me, but i think there is a torque sequence on the oil pan bolts. (work from the middle out)
j_ambrose
Honda CR-V & Element
01-03-2018 06:57 AM
lazyxmofo
03-09-2011 06:26 PM
BANting
12-21-2004 08:26 PM
02 coupe
06-25-2003 01:56 PM
Loveless
04-23-2003 04:57 PM
Quick Reply: changing oil pan
