Tips on installing exhaust
Old Jan 5, 2002 | 09:50 AM
Mike_N_Ike's Avatar
Default Tips on installing exhaust
Does anybody have any tips or pointers they want to offer me before I try this?
I ordered a GReddy evolution system for my 98 civic ex coupe and I figured I'd try. Thanks in advance.
-Mike
Old Jan 5, 2002 | 09:56 AM
ZUL8R's Avatar
Default Re: Tips on installing exhaust (Mike_N_Ike)
it would be nice to have a lift. we installed our header, cat, midsection, and rear section on ramps and stands. it was kinda a pain but hey we got it on. use some liquid wrench on all the bolts and nuts to loosen them up. have a buddy help out. Karl (smokkin rubber) installed his catback himself. goodluck
Old Jan 5, 2002 | 10:02 AM
FifthGearOnline's Avatar
Default Re: Tips on installing exhaust (shane89z24)
i did my cat back system by my self, wasnt that bad.....you may need some kind of impact wrench, either air or electric, depending on how rusted the bolts are....2 of mine broke off, but i had new ones waiting. Just dont rush it, and have lots of WD-40 handy Good Luck
Old Jan 5, 2002 | 10:03 AM
jgale's Avatar
spray the rubber hangers w/ WD40 before you start as well. Makes removal and install a snap.
[Modified by jgale, 2:03 PM 1/5/2002]
Old Jan 5, 2002 | 10:08 AM
clean's Avatar
New User
Default Re: Tips on installing exhaust (jgale)
whenever i do exhausts i take the whole thing off. i just unbolt or break the 2 bolts from the manifold to the cat because the 3rd bolt on top of the cat is hard to get to. i unbolt the 2 bolts then take it off the hangers w/ a little support. then you have the whole thing off and dont have to be under the car to get the cat bolts off and on. it honestly take 15 minutes, cause the 3 cat bolts are always so hard and rusted so just replace the boltes anyway and put on never sieze to get them off easier when you have to put on your turbo!!!!!!!
Old Jan 5, 2002 | 10:14 AM
cccya's Avatar
Default Re: Tips on installing exhaust (clean)
FINALLY your learning jk
Yeah i agree with clean. i've done this many times, and have found it is better and easier to just undo the two bolts from the manifold and the just undo all your hangers and pull the whole thing out. much easier to unbolt things on the ground then it is on your back!
Old Jan 5, 2002 | 10:25 AM
Default Re: Tips on installing exhaust (cccya)
its kind of a pain in the *** how the muffler goes up and over that arm on the right side though oh well its an easy install no matter what
Old Jan 5, 2002 | 06:48 PM
beeboyee's Avatar
Default Re: Tips on installing exhaust (fifthgearonline)
WD40
Old Jan 5, 2002 | 07:32 PM
Gump's Avatar
Default Re: Tips on installing exhaust (beeboyee)
i just took off my b pipe off today and i recommend that you put anti-seize on the cat so that you don't have such a hard time taking it off next time
5lugSlug
Mar 18, 2006 03:20 PM
deviant1
14
Apr 9, 2003 12:39 AM
SamC
Feb 28, 2002 07:37 AM
NSX Bob
Oct 17, 2001 03:55 PM
