93 LS... ignition timing problem
Old Dec 20, 2004 | 05:57 PM
whoa its len 2's Avatar
Default 93 LS... ignition timing problem
I failed smog last week mainly on ignition timing. Smog tech got me at 12 degrees instead of 14-18. I used http://www.c-speedracing.com/h...g.php for a reference on how to set timing. Ive followed the steps over and over again but keep coming up with the same problem. Heres the problem.
I do all the steps and set timing right at 16. I remove the jumper wire on the service connector and check timing again. Its back at 12 degrees again. Is there a reason why my motor likes to set itself at 12 degrees? Im not resetting the ecu or anything. Everything is fine until I remove the jumper wire then Im back to square one. Anyone can help me out on this?
L0WL1FE
Mar 27, 2020 02:41 PM
apaige58
10
Aug 5, 2013 04:36 PM
Dazer 1991
Aug 15, 2012 07:09 AM
Unjockable
Mar 22, 2004 01:23 PM
LudeSi-93
Jun 18, 2001 01:07 PM
