intake, 2.75 or 3' diameter
Old Dec 20, 2004 | 01:28 PM
$$broke_db8's Avatar
Default intake, 2.75 or 3' diameter
was just wondering which intake diameter would produce the most hp. i know it'll be only difference of 1-2 hp, but which diameter would be better.
Old Dec 20, 2004 | 01:37 PM
fast95se's Avatar
Default Re: intake, 2.75 or 3' diameter ($$broke_db8)
That depends on your setup man. (Ex. The standard size AEM CAI for an ls would be 2.5", but for people that put larger cams in their b18b, they most often go with a larger 3" intake to provide the needed air for the larger cams)
Old Dec 20, 2004 | 01:40 PM
Default Re: intake, 2.75 or 3' diameter (fast95se)
so pretty much, for a stock gsr i'll go with 2.75 then if i start going with camshafts, manifold, etc i'll be better off with a 3' intake. Correct???
also would if hurt if i just started with the 3' intake?
Old Dec 20, 2004 | 02:30 PM
KeithsDAteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by $$broke_db8 &raquo;</TD></TR><TR><TD CLASS="quote">also would if hurt if i just started with the 3' intake?</TD></TR></TABLE>
You could start off with a 2165421231 inch Intake and all it will do is just get louder.
I would go with the 3".
Old Dec 20, 2004 | 02:32 PM
purplegsr's Avatar
Intake performance doesn't necessarily depend on size, read this:
http://www.automotivetech.org/...ber=1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95se &raquo;</TD></TR><TR><TD CLASS="quote">That depends on your setup man. (Ex. The standard size AEM CAI for an ls would be 2.5", but for people that put larger cams in their b18b, they most often go with a larger 3" intake to provide the needed air for the larger cams)</TD></TR></TABLE>
The AEM for the LS and ITR use 3" piping, while the GS-R uses 2.75".
If you have a stock Intake manifold, just get 2.75" piping, if you move up to Skunk2 or an ITR manifold, use 3 inch piping. Other than that, the actual diameter isn't going to make a 1-2 hp difference. The design is probably more important, for example, the Iceman intake has tapered piping (3.5 at the filter, 2.75 at the TB).
You can probably get away with a generic intake with a K&N filter or something comparable. Don't worry too much about intake piping size, either one will be fine, just get whatever fits onto your Throttle Body with as little modification as possible.
my_gsr_teg
Apr 25, 2010 10:12 AM
Jo$e L@go
13
Jan 20, 2009 11:30 PM
AznMTboy
Dec 31, 2004 11:51 AM
Jaypee
10
Jan 29, 2004 08:20 PM
