Bad Smell
Old Dec 20, 2004 | 11:54 AM
ScoobCivic's Avatar
Default Bad Smell
car is a 94 dx(140,000) with its original cat/muffler when it warms up this nasty rotten egg smell comes out. at 1st i thought i passes some gas and didnt realise or something died in the engine, but then people told me it could be the brand of gas i use, or bad cat, or bad 02 sensor, someone even told me battery going bad.
i could think its the cat, cuz its old...02 sensor is new with swap, i changed the brand of gas i use...battery going bad?.....anyone have suggestions?
oh also it might be connected to the battery dying issue, takes longer to crank the motor and lights dim if not pressing on the gas......TECH comments are appreciated!!
-J
Old Dec 20, 2004 | 11:56 AM
Lee_Delso's Avatar
Default Re: Bad Smell (ScoobCivic)
You know what, is the smell coming from the engine compartment? Cause if it is and you think it might tie into your battery issues, I think it's you battery over charging. That'll explain the rotten smell.
Old Dec 20, 2004 | 12:03 PM
ScoobCivic's Avatar
Default Re: Bad Smell (Lee_Delso)
comes more from the passanger compartment(inside of the car).
its hard to tell where it comes from when the hood is open and your in a garage
Old Dec 20, 2004 | 12:05 PM
Lee_Delso's Avatar
Well just today when I came to work we had this rotten smell and it turned out that we had left the battery on a battery and it over charged.
Old Dec 20, 2004 | 12:38 PM
PLAN:B's Avatar
Rotten egg smell is usually associated with the exhaust (bad cat)
Old Dec 20, 2004 | 12:41 PM
Deemeetree's Avatar
Electrician
Maybe you need to stop farting.
J/K.
Usually, egg smell points toward your cat being shot.
Old Dec 20, 2004 | 01:45 PM
ScoobCivic's Avatar
i should take an appointment to check out my gastrointestinal tract..
so must be the cat.....thanks guys
possible coincidence with the battery?
Old Dec 20, 2004 | 02:06 PM
HalfAnP's Avatar
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
Default Re: (ScoobCivic)
I'd say the cat as well. The dimming lights sound like an Alt. problem.
Old Dec 20, 2004 | 03:13 PM
caonima's Avatar
Default Re: (HalfAnP)
you left the e-brake on, i do it atleast once a day.
Old Dec 20, 2004 | 03:41 PM
ScoobCivic's Avatar
Default Re: (caonima)
umm, sure buddy, thanks for the thought tho...
:::sarcasm:::
Old Dec 20, 2004 | 10:29 PM
ScoobCivic's Avatar
ha ha ha, he he he..........the stench is gone, just a heads up to everyone, it was the battery and not the cat......everytime the alternater would try to recharge the battery something would go wrong and it would fart out nasty old boiled egg smell. optima yellow came through and fixed the problem.
-J
Old Dec 20, 2004 | 11:33 PM
Yumm Tum Yummm's Avatar
sounds like a dead bird that got caught onto something?
Old Dec 21, 2004 | 12:26 AM
Br1anPham's Avatar
Default Re: Bad Smell (EJ_FaNaTiK_22)
Febreeze.
Old Dec 21, 2004 | 12:48 AM
31flavorscivic's Avatar
Default Re: Bad Smell (Br1anPham)
Good thing you got it taken care of. Wish mine was that easy. I destroyed a cat by rodding a car I used to daily drive. My friends still will not drive behind me when I'm in that car, it was THAT bad.
clappedOut05
Honda Civic (2001 - 2005)
Feb 1, 2019 06:11 AM
denverbc
Honda CR-V & Element
Sep 5, 2017 06:14 AM
mortificationrock
May 22, 2008 02:11 PM
bitz95civ
Dec 23, 2005 06:24 PM
respectblades
11
Feb 6, 2003 03:10 PM
