thermostat modification for cooling..
Old Dec 20, 2004 | 11:46 AM
tgreaves's Avatar
Default thermostat modification for cooling..
I am wondering.. If I remove the center of my thermostat and just leave the outside of the housing there would the coolant still flow slow enough for the radiator to remove heat from the coolant??
This is on a drag car that doesnt have a heater core or anything like that, I just want to keep the temps down and make it eaiser to turn the water pump and free up some lost power..
Old Dec 20, 2004 | 12:38 PM
Dan GSR's Avatar
Default Re: thermostat modification for cooling.. (tgreaves)
I wouldn't gut the thermostat
but you can drill some holes in it
Old Dec 20, 2004 | 05:42 PM
86si's Avatar
i did what you explained and it worked well
Old Dec 21, 2004 | 06:56 AM
plamauski's Avatar
Default Re: thermostat modification for cooling.. (Dan GSR)
Yup drilling holes works well cuz it doen't interfere with thermo operation, just kind of a supplemental flow...it can still regulate temp/pressure somewhat.
Old Dec 21, 2004 | 06:58 AM
tgreaves's Avatar
I know Endyn on one of their motors removed the center of the thermostat just leaving the outer ring of it there and moded the water pump to flow slower and it worked great.. I probably will just drill holes in it to make it work then..
How many holes and what size do I need to drill?
Old Dec 10, 2005 | 09:08 PM
mike93eh
Guest
Posts: n/a
i was told i should drill some holes in my t-stat. is this a good or bad idea.. i live in a winter climate.
shm91
14
Oct 2, 2013 05:05 PM
hollums2k
17
Oct 17, 2010 04:17 PM
nonvtec92
14
Nov 28, 2008 04:50 PM
Arch-Angel
Dec 24, 2004 03:08 PM
bigblockEG
Apr 25, 2003 04:32 PM
