Tein Basic Damper HHHHEEEELLLLPPPPP
Old Dec 20, 2004 | 06:01 AM
EgRedSi's Avatar
Default Tein Basic Damper HHHHEEEELLLLPPPPP
Yo, I just bought some Tein Basic Dampers . No matter what height I set it at it always scraps. Tell me something good. 205/50/16 tire size, the tires aren't the issue, it just when I hit a hard bump or weight shifts suddenly the car gives and scraps. The front is dropped about a inch and a half. The back about an inch. I have the back set almost as high as it can go. Help
Sorry no picks, I don't know how to save pics to an "url".
Old Dec 20, 2004 | 06:51 AM
dwnthehatch's Avatar
Default Re: Tein Basic Damper HHHHEEEELLLLPPPPP (EgRedSi)
What offset are you running on your wheels?
Old Dec 20, 2004 | 07:15 AM
EgRedSi's Avatar
Default Re: Tein Basic Damper HHHHEEEELLLLPPPPP (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">What offset are you running on your wheels?</TD></TR></TABLE>
Hell if I know.
Old Dec 20, 2004 | 08:45 AM
EgRedSi's Avatar
This is the Front
This is the back
This is the car
Tell me what's wrong
Old Dec 20, 2004 | 09:22 AM
Littleton's Avatar
Try adjusting the dampering (should be a little dial thing (set it to the highest number ((stiffest)) (then work downward to suit your driving needs)) not the ride height.
Old Dec 20, 2004 | 09:36 AM
esoterEK..'s Avatar
Default Re: Tein Basic Damper HHHHEEEELLLLPPPPP (Littleton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Littleton &raquo;</TD></TR><TR><TD CLASS="quote">Try adjusting the dampering (should be a little dial thing (set it to the highest number ((stiffest)) (then work downward to suit your driving needs)) not the ride height.</TD></TR></TABLE>
basics dont have damper adjustments....
do you have camber kit?
it could also be the offset of ur wheels being too wide..
Old Dec 20, 2004 | 03:19 PM
EgRedSi's Avatar
Default Re: Tein Basic Damper HHHHEEEELLLLPPPPP (esoterEK..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esoterEK.. &raquo;</TD></TR><TR><TD CLASS="quote">
it could also be the offset of ur wheels being too wide..</TD></TR></TABLE>
Yep, that's what I was told. The offset is too wide.
So will 205/45/16 do better?
Old Dec 20, 2004 | 03:47 PM
EgRedSi's Avatar
The Side
The Back
The Front
so what's the word?
JDM_SOHC
Oct 13, 2008 09:19 AM
highroller54
Mar 23, 2008 08:44 PM
AnthonyG2003
Mar 18, 2006 07:47 AM
Enthalpy
Honda S2000
34
Sep 1, 2005 10:09 PM
Vincent.
Jun 30, 2004 06:40 PM
