This Girly girl needs help on her clutch 93 Honda Civic????
My clutch in my honda is really loose until I am about an inch away from the bottom of my car. Also my gears are tight like I can't get it in gear. But if I pump on my clutch pedal a little bit I can get my car into 1st gear but its real hard. Can anybody help me....please?
If you are to the point where pumping the pedal improves the shifting, I would believe air has entered the hydraulic system. You will need to bleed the system, and completely remove all of the old fluid. The clutch reservoir is mounted to the firewall, just to the right of the brake master cylinder, if you are looking from the front of the car.
707EF8
Jul 29, 2006 08:09 PM
djkendra
Dec 19, 2004 10:00 PM
HELP: Came out to car this morning, clutch floppy, won't engage, completely out of fluid, filled sti
Kristo92
Jun 30, 2004 02:06 PM
