99-00 si rear brakes on a 97 civic
I know that u gotta swap the spindle, e-brake lines and control arm assembly plus some other stuff but what i want to know is, do i need to change the proportion valve or can i just leave the on that came with the car. I won't be doing any autocrossing or anything like that. I just want some better braking power and drums behind nice looking wheels look shitty.
Just get some SS lines for a 99-00 si....I swapped prop valve when I swapped to Si rear brakes, haven't had a problem. I also went with an Si master cylinder, it is just a little bigger.
The proportioning valve isn't super important -- you can keep your existing one on there.
