Match clutch to engine or tranny?
Old Dec 19, 2004 | 11:15 AM
B18aHatch's Avatar
Default Match clutch to engine or tranny?
hey guys. im doin a swap on my buddys hatch. and his engine and tranny are from 2 diffrent. model cars. what clutch does he get the one to match the engine or the one to match the tranny?
Old Dec 19, 2004 | 11:28 AM
Ricey McRicerton's Avatar
Default Re: Match clutch to engine or tranny? (B18aHatch)
Engine. The clutch bolts to it, not the tranny.
Old Dec 19, 2004 | 11:31 AM
Turbogixxer's Avatar
Default Re: Match clutch to engine or tranny? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Engine. The clutch bolts to it, not the tranny.</TD></TR></TABLE>
True, but different trans have different splines. All 94+ have the same splines (B-series).
But if he has a 91 LS trans and uses a 94 b-series clutch, it will not work. Different splines.
Old Dec 19, 2004 | 11:51 AM
B18aHatch's Avatar
Default Re: Match clutch to engine or tranny? (turbogixxer)
soo witch is it? do i match up with the engine or tranny?
Old Dec 19, 2004 | 11:57 AM
What engine and trans are you using?
Old Dec 19, 2004 | 12:29 PM
B18aHatch's Avatar
one of my buddys is dropin a zc in and using a dx tranny in his EF. and i dono yet what my other buddy is doin.
Old Dec 19, 2004 | 01:10 PM
Luserkid's Avatar
If its cable get a cable tranny for the engine
If its a hydro get a hydro tranny for the engine.
Old Dec 19, 2004 | 01:16 PM
hctjohnson's Avatar
match the clutch with the splines on the trans, the clutch pressure plate bolts to the flywheel
Old Dec 19, 2004 | 02:53 PM
BrOkE_ass_sKaNk's Avatar
did the ZC came with a flywheel & clutch?
Old Dec 19, 2004 | 03:16 PM
Trial User's Avatar
Any D series tranny will bolt to any D series motor. If the clutch fits the tranny it will fit the motor so the answer to your question is:
The tranny. Match the clutch to the tranny.
Keep in mind 88 trannies use 21 spline shafts and 88-89 have a smaller clutch disk and flywheel so these will have to match also.
Old Dec 19, 2004 | 03:22 PM
chad's Avatar
Moderator
RICEY....cmon man....you know he has to match the clutch to the TRANNY!!! what if he has a 89 4 speed tranny but has a d16z6 engine.....he'll have the wrong clutch for the car mang....
MDPL8706
Sep 15, 2006 06:15 AM
93civicsedan
May 1, 2005 07:43 PM
solsearching
Oct 3, 2001 10:24 AM
