touchy tps??
Old Dec 19, 2004 | 10:23 AM
zensoku207's Avatar
Default touchy tps??
ok so the motor idles fine now, lsvtec, just cleaned out iacv and ficv's, but after the throttle is touched and closes again it drops almost like its gonna stall, then back up again.....
....i think the head gasket leaks too, from a small oil drip on the upper side of the transmission.....SHITTY....
i've tried tightening the idle screw, and adjusting the tps little by little, but without a voltometer its tough....
but idles ok, a little on the high side, when vtecs engaged blows blue smoke...and idles a little white....
Old Dec 19, 2004 | 02:25 PM
zensoku207's Avatar
nuthin?
Old Dec 20, 2004 | 11:54 AM
tgreaves's Avatar
Default Re: touchy tps?? (zensoku207)
Adjusting the tps sensor without a meter is impossible.. Just go to radio shack and get their $20 meter and then you can adjust it properly..
Old Dec 20, 2004 | 06:27 PM
civic-4-ges's Avatar
Default Re: touchy tps?? (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Adjusting the tps sensor without a meter is impossible.. Just go to radio shack and get their $20 meter and then you can adjust it properly..</TD></TR></TABLE>
Definately, you would be surprised at how much the TPS voltage changes by merely tightening down the attachments screws.
Old Dec 21, 2004 | 05:41 AM
tgreaves's Avatar
Default Re: touchy tps?? (civic-4-ges)
I remember it was a pain in the *** to get it to .45 volts when tightened down..
Now I run the AEM EMS where you can calibrate the tps throught the software..
Old Dec 22, 2004 | 03:01 AM
zensoku207's Avatar
sweeeeet.....
does vafc2 do that??
Old Dec 22, 2004 | 03:56 AM
Default Re: (zensoku207)
VAFC does not calibrate for it, only reads it
Old Dec 22, 2004 | 05:20 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zensoku207 &raquo;</TD></TR><TR><TD CLASS="quote">sweeeeet.....
does vafc2 do that??</TD></TR></TABLE>
Nope..
Old Mar 21, 2005 | 10:47 PM
#1151's Avatar
does vafc2 do that??</TD></TR></TABLE>leave this country now. scammers
WARNING DO NOT BUY FROM HIM
hadehatch
Dec 4, 2024 01:46 PM
SilverWarrior
21
Mar 14, 2008 07:09 PM
nek9
14
Nov 26, 2006 06:13 PM
skimb37
Apr 5, 2005 05:58 PM
paul93sir
Feb 5, 2004 11:26 AM
