no oil pressure in head = no vtec someone help
Old Dec 19, 2004 | 09:35 AM
queez's Avatar
Default no oil pressure in head = no vtec someone help
hey guys just finished putting my motor back together once again. i had the machine shop put the head all together . but now i;'m not getting enough oil pressure at vtec spool mechanism to engage v tec. i dont know whats going on.. are there any freeze plugs in block that he may have forgotton to put in?? the solonoid seems to be working and so does the pressure gauge. but not enough pressue to kick in vtec
Old Dec 19, 2004 | 08:05 PM
mmuller's Avatar
Mad Scientist
Default Re: no oil pressure in head = no vtec someone help (queez)
did you put the oil control thingy on the block?
what psi are you getting?
Old Dec 19, 2004 | 08:43 PM
queez's Avatar
Default Re: no oil pressure in head = no vtec someone help (mmuller)
i get 0 cmoing out the check port in head
Old Dec 19, 2004 | 09:02 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by queez &raquo;</TD></TR><TR><TD CLASS="quote">i get 0 cmoing out the check port in head </TD></TR></TABLE>
stupid question, but did you jump the vtec sol. when checking pressure to the vtec oil port?
did you check it with engine rpms over 3k?
Old Dec 19, 2004 | 09:40 PM
queez's Avatar
yeah did all that.. and still get 0. i even removed the oil pressure sender at spool mechanism and i get like 0 ... i dont know whats wrong
i'm getting 50+ psi at bottom of block
Old Jan 3, 2005 | 02:00 PM
graphic's Avatar
bump i am having the same exact problem on my h22
Old Jan 3, 2005 | 06:02 PM
queez's Avatar
Default Re: no oil pressure in head = no vtec someone help (graphic)
i found it to be the machinist left out an oil freeze plug .. . in the head
Old Jan 3, 2005 | 06:12 PM
nvmyb20hatch's Avatar
there is a dowel with an o-ring that goes underneath the center cam cap on all vtec b series motors that provides a restriction to allow enough oil pressure to push the pistons that engage the vtec lobe. if thats not installed or installed improperly vtec will not engage. not sure about h series though. just my .02 you said you found the problem, but in the past ive found that to be an issue with vtec not engaging.
tobster
Mar 13, 2011 12:32 PM
bigmacks
Aug 25, 2005 02:08 PM
queez
Dec 18, 2004 04:32 AM
b20b
Feb 22, 2002 03:42 AM
zdr262
Oct 23, 2001 01:51 PM
