skipped two teeth
Old Dec 19, 2004 | 08:17 AM
EFin' Kyle's Avatar
Default skipped two teeth
ok i got oil on my timing belt and it skipped two teeth on the intake side. what damage did it do? the garage was driving it when it broke they fixed the timing though. now my car idles rough and wont hold a charge. any ideas what could have gone wrong? any ideas on damage?
-Kyle
Old Dec 19, 2004 | 09:06 AM
CRXracer88's Avatar
Default Re: skipped two teeth (Slow *** CRX)
does the car make good power or does it fell like it has a miss. i remember a car i had jumped timing and bent to intake valves. the car started and ran but it sounded like it had a miss at idle. that could cause the rough idle your getting.
Old Dec 19, 2004 | 09:20 AM
EFin' Kyle's Avatar
Default Re: skipped two teeth (CRXracer88)
so intake valves could be bent? it ran but not as much power and idle was bad it would alwasy jumped around and would sometimes die.
Old Dec 19, 2004 | 10:50 AM
1point5CRX's Avatar
take the head off and get it checked.
Old Dec 19, 2004 | 01:29 PM
skunk2eg's Avatar
Default Re: skipped two teeth (1point5CRX)
most likely bent valves, although you could be lucky and nothing happened
Old Dec 19, 2004 | 03:44 PM
slowpokesi's Avatar
is this a dohc b16a?
if so you probably bent your valves, b16a's are interferance motors, and 2 teeth is probably like 5 degrees advance wich is bad.
im guessing this is dohc since u said, intake side!
Old Dec 20, 2004 | 10:38 AM
EFin' Kyle's Avatar
Default Re: skipped two teeth (slowpokesi)
ya sry i forgot to say its a 1st gen b16a
Old Dec 20, 2004 | 12:08 PM
tgreaves's Avatar
Do a compression and leakdown test on the motor.. That will tell you if you bent any valves..
Old Dec 20, 2004 | 01:22 PM
WhiteDSM520's Avatar
Default Re: skipped two teeth (tgreaves)
If you do a leakdown or compression test you're compression results might be a little silly if you don't fix the t-belt first. Once you fix it go ahead and test it. Good luck.
Old Dec 20, 2004 | 01:50 PM
EFin' Kyle's Avatar
Default Re: skipped two teeth (WhiteDSM520)
ok well since th car was in the mechanics hands when they broke it dont they have to fix it themselves? also they did set the belt back but that is it. so would they or wont they have to fix it free? anyone know?
Old Dec 20, 2004 | 02:17 PM
aaronhume's Avatar
well I'm sure they don't want to but if you find a good lawyer they might have to.... it all depends on what you signed when they gave the car back to you... all legal stuff... but I could be wrong...
1badteg
Jun 20, 2007 03:36 AM
yohan
Jun 19, 2006 10:13 AM
Morning Call
Jun 16, 2005 12:23 PM
SLOW4drINTEG
Feb 19, 2004 01:57 PM
