Oil Feed and Return lines setup on turbo...is this ok?? help needed. (pics inside)
Old Dec 19, 2004 | 07:13 AM
japrex's Avatar
Default Oil Feed and Return lines setup on turbo...is this ok?? help needed. (pics inside)
ok, this is how my oil feed and return lines are setup. i need to know if this is ok. as you can see in the pics my oil feed line is slightly on the bottem side and my oil return line is slightly on the top side. i would like to keep it as is because i finally got the lines and everything to fit good. but if this needs changed then i will do so. stupid mistake by me. tell me what you think. suggetions are welcome.
Old Dec 19, 2004 | 07:19 AM
f22b2tdave's Avatar
Default Re: Oil Feed and Return lines setup on turbo...is this ok?? help needed. (japrex)
you're kidding right? return is gravity fed, i do not think that will work unless you are turning your car into a smoke machine. no offense but yeah thats not going to work.
id like to see some more pics though, looks like apretty clean setup other than the lines.
Old Dec 19, 2004 | 07:21 AM
f22b2tdave's Avatar
damnit i am not good at the interweb. double post, stupid back button.
japrex's Avatar
i know i know...stupid me. i know better than this but i just thought i would get some opinions before i change it. i will post a few more pics up in a bit.
DOHCarp's Avatar
DO NOT run it like that! You have to clock (rotate) the center housing so the return line will be on the bottom. The only thing that will drain your oil is gravity, and the way you ahve it right now will surely blow your seals.
Loosen the bolts on the compressor and turbine housing to roate the center section.
Old Dec 19, 2004 | 07:46 AM
TurboEH2's Avatar
Default Re: Oil Feed and Return lines setup on turbo...is this ok?? help needed. (DOHCarp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCarp &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT run it like that! You have to clock (rotate) the center housing so the return line will be on the bottom. The only thing that will drain your oil is gravity, and the way you ahve it right now will surely blow your seals.
Loosen the bolts on the compressor and turbine housing to roate the center section.</TD></TR></TABLE>
Old Dec 19, 2004 | 08:40 AM
Bailhatch's Avatar
Default Re: Oil Feed and Return lines setup on turbo...is this ok?? help needed. (LSturboEH2)
oh my! that's unreal considering how many pictures and threads there are about this. At least you checked first
might want to have the WG tube fixed too. it should point down ideally or at least straight out.
Old Dec 19, 2004 | 09:14 AM
fast93accord's Avatar
Hahahahahhahahahahah, I almost pissed my pants when i saw those pics. Hahahhahahaha. Building a turbo car is not like running N/A. You actually have to know the theory and design to do it sucessfully. Please do yourself a favor. Have someeone with experience help you with your setup/tuning.
Old Dec 19, 2004 | 07:52 PM
PrettyLude's Avatar
i hope u didn't drive on it like that, real easy to blow the seal out just like that
Old Dec 19, 2004 | 07:55 PM
m R g S r's Avatar
Default Re: Oil Feed and Return lines setup on turbo...is this ok?? help needed. (f22b2tdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f22b2tdave &raquo;</TD></TR><TR><TD CLASS="quote">you're kidding right? .</TD></TR></TABLE>
I don't think so, seeing that he spent $$ on a 90 degree AN fitting hahahaha
BlueShadow
Dec 18, 2005 10:06 AM
birz
Jun 4, 2004 06:03 AM
Hoosier Daddy
Jan 7, 2004 10:26 PM
FOrSfEd
Nov 21, 2003 07:39 PM
T25 civic
Oct 15, 2002 12:52 PM
