Which GT series turbo for my goal????
Old Dec 18, 2004 | 11:00 PM
rextec's Avatar
Default Which GT series turbo for my goal????
here is the setup:
d16z6
eagle rods
cp pistons 9.2:1
91 octane pump gas
up to 16 psi of boost
i am wanting to get about 350whp on around 16psi of boost on pump gas and quick spool. i was looking at the gt2871r since it is cheaper than the gt28rs and able to produce more power. i was also looking at the gt28r because i can get a good deal on one at the moment. post up your suggestions!
Old Dec 19, 2004 | 02:53 PM
rextec's Avatar
bump!!!!
Old Dec 20, 2004 | 10:48 AM
rextec's Avatar
wow, no one has an answer?
Old Dec 20, 2004 | 11:09 AM
mike1114's Avatar
Default Re: (rextec)
you pretty much answered it yourself:
"the gt2871r"
Old Dec 20, 2004 | 11:21 AM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rextec &raquo;</TD></TR><TR><TD CLASS="quote">wow, no one has an answer?</TD></TR></TABLE> Looks like you'll get about 315whp or so off of 16psi w/ the GT28RS disco potato. You'll need to bump up boost a little for 350.. About 18psi or slightly more
Old Dec 20, 2004 | 12:03 PM
mike1114's Avatar
Default Re: (TheShodan)
TheShodan---------Listen to this guy.....He knows stuff!!!!!
Old Dec 20, 2004 | 02:24 PM
rextec's Avatar
how about the gt28r??? around how much whp would i get at 16psi?
Old Dec 20, 2004 | 04:25 PM
Mighty Mintos's Avatar
how bout a Gt2835 Pro-S turbo?
Old Dec 20, 2004 | 04:54 PM
rextec's Avatar
not for $3000! no thank you!
Old Dec 20, 2004 | 05:26 PM
i have one used for $1400... https://honda-tech.com/zerothread?id=1088538
Old Dec 23, 2004 | 01:27 PM
rextec's Avatar
anyone know about how much whp on my setup the gt28r will do at 16psi?
Old Dec 23, 2004 | 01:45 PM
96-EJ6 B18C's Avatar
Sorry to thread jack but I have a very similar setup and I'm very seriously considering the GT 3071 and opnions on this one? I'm shooting for 350 WHP and a quick spool for autoX.
Old Dec 23, 2004 | 08:42 PM
rextec's Avatar
thats what im shooting for aswell, but on a d16z6.
Old Dec 23, 2004 | 08:52 PM
onePOINTsix's Avatar
a "Disco Potato" GT28RS is perfect for 350hp, well actuall more like 325hp. If you are dead set on hitting 350hp then get a GT2871R but your going to spool slower expecially on a D16. FYI the GT28R is a cheeper, not quite as advanced turbo as the RS, the GT28 was redesinged by garrett to spool faster and provide better overall flow and they did a great job at it. also FYI it's called the "Disco Potato" becasue the compressor flow map is in the shape of a potato
Old Dec 23, 2004 | 08:53 PM
O3DigitalBath's Avatar
Default Re: (onePOINTsix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onePOINTsix &raquo;</TD></TR><TR><TD CLASS="quote">. called the "Disco Potato" becasue the compressor flow map is in the shape of a potato </TD></TR></TABLE>
ah, so thats why lol learn something new every day
Old Dec 25, 2004 | 07:27 AM
95c1v1cs1's Avatar
Default Re: (O3DigitalBath)
If your not getting a Ball Bearing, a GT32 works very nice. I have one on my D16Z6 beater car.
Corey
Old Dec 25, 2004 | 11:47 PM
rextec's Avatar
Default Re: (95c1v1cs1)
how does your d16 spool it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95c1v1cs1 &raquo;</TD></TR><TR><TD CLASS="quote">If your not getting a Ball Bearing, a GT32 works very nice. I have one on my D16Z6 beater car.
Corey</TD></TR></TABLE>
Old Dec 26, 2004 | 04:57 AM
integlspwr2k's Avatar
if you get the disco potatoe, aren't you out of the efficency range already?
Old Dec 26, 2004 | 06:32 AM
MI KENT's Avatar
its called the disco potato (gt28rs) because sport compact car had a project b15 (2000-up) nissan sentra w/sr20det. the car was chameleon and was running the first ever gt28rs 'disco' potato turbo. (and the compressor maps do look like a potato LOL). How's the spool of the gt28rs on say 14psi with a d15b?
Old Dec 26, 2004 | 09:24 AM
TheShodan's Avatar
Moderator
Default Re: (MI KENT)
Well. for a built D16, going with a Jounal Bearing turbo is always in option in which I'd use a slightly modified (spec wise) GT32E, to allow the lack of amount of torque that the SOHC d16 has. One thing about the Ball-bearing units (especailly those a little larger than the 'potato') is that they like HARD boost, and typically the benefits of such a turbo aren't seen until about 14psi and above, other than that, it may be a bit more cost efficient to go with something like the GT32E, but slightly modified.
I guess what I'm trying to figure out is instead of just asking what rpms a certain turbo gives for a certain hp, it would be a bit more helpful if you gave us some insight on what goals you're actually trying to accomplish. What is the mission of your car?
Old Dec 26, 2004 | 09:39 AM
AccidentproWn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MI KENT &raquo;</TD></TR><TR><TD CLASS="quote">its called the disco potato (gt28rs) because sport compact car had a project b15 (2000-up) nissan sentra w/sr20det. the car was chameleon and was running the first ever gt28rs 'disco' potato turbo. (and the compressor maps do look like a potato LOL). How's the spool of the gt28rs on say 14psi with a d15b? </TD></TR></TABLE>
yeah, i was under the impression that the sentra was nicknamed disco potato so the turbo inherited the name.
Old Dec 26, 2004 | 07:35 PM
Default Re: (AccidentproWn)
i thougth it was named disco potatoe because it was jsut all hype, and if you put a potatoe in the spot light with flashy lights, flashy names, loud music, you get a disco, but at the end, its still nothign but a potatoe..
Old Dec 26, 2004 | 08:24 PM
rextec's Avatar
my goals are a broad power band with a max output of 350whpish, with quick spool. i have an sc34 for my d16z6 but this turbo is overkill for my application and will provide a peaky powerband and slow spool.
Old Dec 27, 2004 | 08:05 AM
95c1v1cs1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rextec &raquo;</TD></TR><TR><TD CLASS="quote">how does your d16 spool it?
It sees 5 psi by like 3200.
9-10psi by like 3800
Maybe not quite quick enough for you.
JZs15
Feb 26, 2009 03:21 PM
mikelax125
Honda Civic (2001 - 2005)
Sep 27, 2006 08:26 AM
Wo-Nelly
Feb 1, 2004 05:53 AM
TurboTeG4
13
Sep 21, 2002 04:54 AM
