Need to get a new 12 Volt wire inside.
Old Jan 4, 2002 | 04:56 PM
Avian's Avatar
New User
Default Need to get a new 12 Volt wire inside.
Need to find a place to get 12 Volts to a 16 Guage wire. Can't find any open grommets, etc. Would rather have a constant 12 Volt, but ignition will work. Don't want to do any drilling.
Old Jan 4, 2002 | 06:27 PM
infinkc's Avatar
Default Re: Need to get a new 12 Volt wire inside. (Avian)
depends what you are using it for, if its minor just tap off the ignition harness, will be a White wire for constant 12v or if you look at your fuse panel there are spots that you can attach a female spade connector to and get 12v also. hth
wwolf771177
Feb 4, 2014 02:25 PM
98civhatch
Jul 5, 2009 05:58 PM
85mm LS VTEC
Apr 11, 2005 06:46 PM
n0 iNTegRiTY
Audio / Security / Video
Feb 25, 2004 08:51 PM
ragejed
May 19, 2003 01:14 PM
