power outlet hookup?
Old Feb 25, 2004 | 02:29 PM
n0 iNTegRiTY's Avatar
Default power outlet hookup?
I have this posted in the Integra forum, and thought I might get a better response here.... please help.
https://honda-tech.com/zerothread?id=779744
Old Feb 25, 2004 | 03:05 PM
Default Re: power outlet hookup? (n0 iNTegRiTY)
c'mon....
Old Feb 25, 2004 | 07:33 PM
brads94accord's Avatar
well depending on where you are going to put it, your best bet would be to run it off a 12 volt source such as the 12 volt ignition wire in your ignition harness that runs 12 volts with the key on. make sure you run a fuse on that wire too, within 8 inches of where you tapped in.
Old Feb 25, 2004 | 08:51 PM
snoochtodanooch's Avatar
Default Re: (brads94accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brads94accord &raquo;</TD></TR><TR><TD CLASS="quote">well depending on where you are going to put it, your best bet would be to run it off a 12 volt source such as the 12 volt ignition wire in your ignition harness that runs 12 volts with the key on. make sure you run a fuse on that wire too, within 8 inches of where you tapped in.</TD></TR></TABLE> that would work well.
Extreez
Audio / Security / Video
Apr 11, 2007 04:19 PM
staticrex
Nov 22, 2004 02:33 PM
DI9ITAL
Feb 12, 2004 09:12 AM
Avian
Jan 4, 2002 06:27 PM
