o-ring head
Old Dec 18, 2004 | 09:32 PM
evilone's Avatar
Default o-ring head
Anyone have any success o-ringing a h22 head?i have a gasket issue and i have o-ringed blocks before but never a head. Anyone have any info?
Old Dec 18, 2004 | 11:32 PM
PrettyLude's Avatar
you would have to ask earl about this
Old Dec 19, 2004 | 09:44 AM
evilone's Avatar
Default Re: (PrettyLude)
bump.... where is earl?
Old Dec 19, 2004 | 02:03 PM
NJIN BUILDR's Avatar
Default Re: o-ring head (prostock)
O-ringing the head is a little more work than a block.Locating the placement of the ring is the problem.The biggest reason the domestics(mostly ford 5.0l)is not having to pull and disassemble the bottom end.They use a plate that bolts to the head as a template.I don't see any performance advantage to having it in the head.
Glenn
Old Dec 19, 2004 | 05:12 PM
PrettyLude's Avatar
what is the gasket issue?
Old Dec 19, 2004 | 06:14 PM
RMS's Avatar
RMS
find someone with the isky o-ringing tool and you can o-ring the block in the car.
Old Dec 19, 2004 | 06:54 PM
evilone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">what is the gasket issue?</TD></TR></TABLE>
90mm h22
Old Dec 19, 2004 | 06:56 PM
evilone's Avatar
Default Re: (prostock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">O-ringing the head is a little more work than a block.Locating the placement of the ring is the problem.The biggest reason the domestics(mostly ford 5.0l)is not having to pull and disassemble the bottom end.They use a plate that bolts to the head as a template.I don't see any performance advantage to having it in the head.
Glenn</TD></TR></TABLE>
honestly I'm not looking for any advantage but more or less am lazy and don't want to pull the block if i don't have to
Old Dec 19, 2004 | 07:09 PM
PrettyLude's Avatar
90mm is big on a h22, normally the biggest i've seen on a h22 is 89mm, leave some room for error man
Old Dec 20, 2004 | 05:06 AM
evilone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">90mm is big on a h22, normally the biggest i've seen on a h22 is 89mm, leave some room for error man</TD></TR></TABLE>
yeah i know, but unfortunately i didn't build it, i am just playing the cards i was dealt
Old Dec 20, 2004 | 12:01 PM
evilone's Avatar
bump
Old Dec 21, 2004 | 02:43 PM
evilone's Avatar
bump
Old Dec 22, 2004 | 02:37 AM
Default Re: (RMS)
Like I said,o-ringing the head is a bit of a project.I've used the Isky tool and it work very good.Isky will rent you the tool and sells the wire also.With a little care you could do it to an assembled engine.
Glenn
1fastlude1
Aug 16, 2008 06:14 PM
H-EK22
28
Mar 8, 2008 09:31 AM
sivikvtec
Aug 16, 2006 05:10 PM
Option
Dec 28, 2004 04:45 PM
evilone
Dec 21, 2004 03:34 PM
