p72 or p13 on h22
Using a P28 here, my buterflies are removed. No problems, but then again, I have a Hondata. The car originally had a P13, and ran just fine, I just prefer to limit my electronics and only tune the ECU and not numerous other items. Hondata did not have a kit for the P13, and the P72 was too expensive.
In the end, it is up to what you intend to do with the car...
Jason
Jason
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FSTASNTZ »</TD></TR><TR><TD CLASS="quote">Using a P28 here, my buterflies are removed. No problems, but then again, I have a Hondata. </TD></TR></TABLE>
Why did you remove your IABs when your hondata can control them?
Hondata can control them if I have an ECU that recognizes them, like the P72, but instead I have the P28. I mainly removed them to make a little more power up top, and with such a big turbo, wanted the lack of power down low to the car can get settled between shifts and off the line before the boost gets crazy.
Jason
Jason
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FSTASNTZ »</TD></TR><TR><TD CLASS="quote">Hondata can control them if I have an ECU that recognizes them, like the P72, but instead I have the P28. </TD></TR></TABLE>
http://www.hondata.com/forum/v...=iabs
Yes, if you are running a turbo, it is good to remove them.
p72 lacks egr, as does p28...but, p28 lacks a knock sensor as well...p13 has both of these features, but keep in mind the p72 and p28 both require customization to work (correctly) with the h22...
what gains/losses to u get from removing the IAB's in a h22a? i'm goin the turbo route, is it better to take them out? i'm going to be using uberdata with a p28.
