B series swap and header clearence question
Old Dec 18, 2004 | 06:24 PM
The Mugenator's Avatar
Default B series swap and header clearence question
I'm going to swap in a B16a2 and cable tranny into my 90 CRX, my friend told me that with that motor in, I would have to get a different radiator in order to accomodate an aftermarket header. Is this true, if so what are my options for a radiator that looks good, is funtional and can handle the cooling duties on this motor. With that said, what are my header options??
Old Dec 18, 2004 | 06:55 PM
Teal Turd's Avatar
Default Re: B series swap and header clearence question (The Mugenator)
I have a 91 hatch w/ a B18c5 and I was told the hood would clear the valve cover......well it did. There should be no reason why you would anything extra except a hood...maybe. It should all drop in just fine
Old Dec 18, 2004 | 07:04 PM
drdisco69's Avatar
Your friend doesn't know what he's talking about. The only time you'll have a clearance issue in the front is with a 4-1 header, and then the only thing in the way is the front crossmember, not the radiator. Now a turbo might need some special consideration...
Old Dec 18, 2004 | 07:49 PM
slowpokesi's Avatar
Default Re: B series swap and header clearence question (Teal Turd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teal Turd &raquo;</TD></TR><TR><TD CLASS="quote">I have a 91 hatch w/ a B18c5 and I was told the hood would clear the valve cover......well it did. There should be no reason why you would anything extra except a hood...maybe. It should all drop in just fine</TD></TR></TABLE>
he was talking header clearance not hood clearance.
your friend is wrong about the radiator, but pretty much no header made for a b16a will clear the x member of a ef, you are going to have to "notch it a little bit, its no biggy!
Old Dec 18, 2004 | 08:24 PM
misfithamster's Avatar
Default Re: B series swap and header clearence question (slowpokesi)
with a 4-1 header your gonna need some deffinate notching.. i promise and ground clearance is tight even if your stock height.. ask me how i know
Old Dec 19, 2004 | 04:40 AM
BNiceB16's Avatar
Default Re: B series swap and header clearence question (misfithamster)
I have a dc sports 4into 1 header and radiator clearence is not a prob. but I did have to notch the front crossmember
Old Dec 19, 2004 | 06:36 AM
QUiKSR20's Avatar
Default Re: B series swap and header clearence question (BNiceB16)
DC 4-1 Tons of room with the Rad.. But def had to get an aftermarket " in my case Z10 " Crossmember to fit it. Had to also notch the hood to clear the cylinder head of the B18C and I def dont recomend lower than stock ride height or your going to smash your header.. Looking into a diff 4-1 soon like SMSP or ANR for more clearance and HP.
Heres a pic or 2 showing the clearance.
Old Dec 19, 2004 | 07:46 AM
SiRex91's Avatar
Default Re: B series swap and header clearence question (QUiKSR20)
I've had a DC 4-1 and a DC 4-2-1 on my B16 CRX and both headers cleared my thicker Fluidyne radiator with tons of room to spare. All you need to do is notch your OEM front crossmember or switch to a tubular front crossmember like Full-Race
B18c1vicrx
10
Aug 15, 2007 06:22 PM
USDMSiR
17
Aug 14, 2006 05:28 AM
h22a193
Nov 9, 2005 07:52 PM
user 996328629
11
Nov 19, 2004 07:56 PM
