CTR Pistons on Eagle Connecting Rods.
I have a set of CTR pistons and Eagle rods sitting right now.. The rods seem a little think at the top where it connects into the piston.. It actually wont fit in. Has anyone expiremented with this? Can I just grind the top of the rods down a tiny bit to make it fit?
As far as I know, OEM pistons will not work with aftermarket rods,....but you can put aftermarket pistons on OEM rods. That's from my experience.
circlips is a grove in the piston so u can install a C-clip in there to keep the wrist pin from sliding out of the piston and rod assembly. i dont think u can press wristpins onto aftermarket rods. u need circlips to keep the wristpins attached to the pistons and rod
vtec69
Jun 17, 2002 09:41 AM
